Results 1 to 9 of 9
05-31-2016 11:25 PM #1
- Join Date
- Jun 2014
- Reputation
- 10
- Posts
- 28
G752VY: 2.5 hours battery life on average use?
Its seems battery life is getting shorter every week. how long your battery last?
i bought this laptop about 2 month ago.
06-01-2016 02:50 AM #2
JustinThyme PC Specs Laptop (Model) G752VY-DH72 Motherboard Rampage VI Extreme Processor I9 9940X Memory (part number) 64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17 Graphics Card #1 ASUS Strix 2080Ti O11G @ 2.1GHz Graphics Card #2 ASUS Strix 2080Ti O11G @ 2.1Ghz Graphics Card #3 ROG Nvlink Graphics Card #4 Have to feed animals Sound Card External Audioengine D1 24 bit 192kbps DAC Monitor ASUS PG348Q @ 100Hz Storage #1 Intel 905P 480GB U2 flavor Storage #2 Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1 CPU Cooler HeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS Case Phanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM Power Supply Corsair AX 1500i Keyboard ASUS Claymore Mouse ASUS Spatha, Logitech MX Master Headset Sennheiser HD 700 Mouse Pad ASUS ROG Sheath Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub OS Win10 Pro 1809 Network Router NetGear NightHawk X10 Accessory #1 NetGear Prosafe 10GBe Switch Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,855
I've had my machine since January and have yet to run it on battery long enough to find out. About the only battery time its gets is when I'm moving from one room to another.
06-02-2016 04:51 AM #3
- Join Date
- Jun 2014
- Reputation
- 10
- Posts
- 28
why you even need a laptop then?
06-02-2016 05:52 AM #4
Gustave PC Specs Laptop (Model) Asus ROG G703GXR - 9980HK - DDR4 64GB - 3x nm2 SSD 1.5TB [RAID0] - 1x SSD Samsung 2TB Motherboard Asus Rampage IV Extreme Processor Core i7 4960X Memory (part number) 32GB Corsair CMT16GX3M4X2133C9 Graphics Card #1 EVGA GFX Titan Graphics Card #2 EVGA GFX Titan Monitor Dell S2340T Storage #1 8x Crucial RealSSD C300 @ 3Ware 9750-8i RAIDCntrlr 1.85 TB CPU Cooler Corsair H100i Power Supply Corsair AX1200 Network Router Draytek Vigor 2960 / Ruckus Wireless ZD1200
- Join Date
- Aug 2012
- Reputation
- 13
- Posts
- 122
Lot of power in a small size!
06-02-2016 03:59 PM #5
Clintlgm PC Specs Laptop (Model) Asus G752VY DH72 Motherboard Asus Z97 Pro WiFi and /Z97 Pro A Processor I7 4790K Storage #1 512 GB M.2 Samsung 960 Pro Storage #2 1 TB Samsun 850 Pro Case Cool Master Haf OS Win 8.1 Pro and Win 10 Pro
- Join Date
- Jul 2012
- Reputation
- 111
- Posts
- 4,181
Yes lots of us don't even game, we just want a powerful desktop replacement. My Case is I work remotely and bring my notebook from site to site staying plugged in at each site. I have my Smart Phone for traveling or if I flew more I would have a tablet just for those times. For me the battery is use as a UPS after 4 years now It seems the battery will last more than a hour since the last time I had unplugged it due to thunder storms and forgot to plug it back in. These notebook draw a lot of power even just sitting there Idle so if your getting 2.5 to 3 hours I think that would be pretty good.
G752VY-DH72 Win 10 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
06-04-2016 03:13 AM #6
- Join Date
- Feb 2016
- Reputation
- 18
- Posts
- 118
I have a G752VT, but I get anywhere from 1.5-3.5 hours of battery life depending on what I am doing and how bright the screen is.
Additionally, you can use something like CPUID HWMonitorto see the current state of your battery. As time goes on you will see battery wear that will decrease your laptop's battery life.
I've had this laptop for just over two months and the laptop currently has 4% battery wear. So some loss of capacity, but not too much.
06-04-2016 04:13 AM #7
- Join Date
- Jun 2014
- Reputation
- 10
- Posts
- 28
06-04-2016 06:49 AM #8
- Join Date
- Mar 2015
- Reputation
- 8
- Posts
- 513
14% is not the end...
after one year i got 25 % wear level
only 120 min left and blinking charging led (all signs for faulty battery)
06-04-2016 09:08 AM #9
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,855
I have other devices that are for extended run time with battery life at 10+ hours. I did my research before buying and knew that every high power portable on the market has a short battery run time. Its the nature of the beast. You cant expect to get 50 MPG from a car that goes 0-60 in 4 seconds either.
I bought my machine as a desktop replacement. It sits on a desk 90% of the time plugged in with a 27 inch monitor attached, lid closed and external mouse and keyboard. If I want to take it elsewhere, I can.
Batteries only have so many charge/discharge cycles. Every time you discharge it your wear level increases.
