stable system after a 15min test prime95, cpu temp max 86 °.
stable system after a 15min test realbench, cpu temp max 75 °
My current settings are:
XMP profile active 10-12-12-31-2t 2401mhz 1.65v
base clock: 100.0
Core ratio: x46
Cache ratio min / max: x40
the voltages manual
Core voltage: 1.28
Cache voltage: 1.19 is the default fix to manual
system agent Offset: +0.2
dram voltage: 1.65
initial / eventual cpu voltage: 1.86 is the default fix to manual
to stress test better prime95 or realbench or XTU ??
Why prime95 I note with temperatures so high?
Now I try with x48 ratio and 1.35 vcore
Matt_El_Condor
