Maximus VIII Extreme Multi-GPU Total System Crash
Synthetic_Frost
I just built a new system, and having multiple GPUs plugged into any combination of PCI-E slots cause major system instability.
CPU: Intel Core i7-6700k
Mobo: ASUS Maximus VIII Extreme
GPU: nVidia GTX 1080
RAM: Corsair Vengeance 64GB DDR4 3200
Storage: Two Samsung 850 Pro 512GB SSD's and two 6TB WD Black Series HDDs
PSU: Corsair AX860i
Case: Corsair 750D
Okay, so I plugged my two older GTX 770's from my previous Haswell rig into the new Skylake rig while I'm waiting for my GTX 1080 to arrive, and the system became very unstable. My newly and freshly installed Windows 10 installation crashes and the entire PC reboots the second I try to enable SLI with my 1440p monitor hooked up.
If I unplug the monitor and only use my old secondary 1080p screen, I can enable SLI, but the moment I launch a game or anything that uses the GPUs, the entire PC actually goes into slow motion. Whether it's the desktop UI, a game, or the sound, it all slows down like it's tripping on acid, and then everything freezes with the screen showing MASSIVE artifacts, and then auto-reboots. This happens whether SLI is actually enabled or not, as long as both GPUs are plugged in.
I've tried the last several sets of nVidia drivers. Nothing.
I've tried putting the GPUs back in the older Haswell system, and SLI works fine. So it's not the GPUs. My next thought was that the PSU must be faulty, since it acts like it's not getting the power it needs, despite the PSU being a higher grade PSU with over 100w more power. So I put in the Haswell rig's HX750 into the new rig, replacing the newer AX860i I bought for the new rig, and it did the same thing. The PC crashed. A voltmeter also shows the AX860i delivering very smooth power across the 12v rail. So the PSU is ok.
I tried unplugging all but one RAM stick, and after trying out all four sticks individually one at a time, the system still crashes.
So then my heart sunk as I realized it's gotta be the Maximus VII Extreme motherboard. I tried reinstalling Windows 10, and that didn't help.
To be clear, the system works 100% when only a single GPU is used. I've tried changing the power management settings in both the UEFI and Windows power settings, I've tried four different UEFI revisions, and tried setting the PCI-E to Gen 2. It's almost acting like either the motherboard is not supplying enough power to the cards, or inserting two GPUs is triggering some kind of invisible overclocking, because that's how it's acting. I have everything set to stock settings and factory defaults, but it acts like it's an unstable overclock, despite temps across all parts sitting around 20ºC.
Windows Event Viewer shows no record of the crashes either.
Is this a know issue? Should I RMA the board?
7 REPLIES 7
Maikal
Just for kicks go into the bios of your Maximus VIII Extreme and disable Thunderbolt 3. Then see if you can enable SLI without issues... I've had some odd things happen with my Fury X's in Crossfire unless I do this.
Sadly that was one of the first things I thought of as well, but turning it off didn't do anything. At this point I've tried almost everything. I can't even get any useful crash logs from any of the apps or games that trigger the crash. I think I'm just going to RMA the board and go for a more midranged Gigabyte board. Never had any trouble with them.
Good luck!
Menthol
Level 14
Synthetic Frost,
Welcome to the forums, sorry to hear your having issues, I just tried dual 1080's and my second card would go from pcie 3.0 to 2.0 to 1.1 and sli even though activated didn't perform correctly, it didn't crash the system but when i would open the new EVGA precision software sometimes my system would freeze and would have to hard reboot, I haven't had time to research the issue, I do not have the auxiliary power connected at the bottom of the motherboard (EZ_PLUG) to give extra power to the pcie slots, I will try and see if I can find the issue this weekend, I already have the Thunderbolt module disabled
I do not have this issue with these cards on my RVE and the Beta MSI for 1080 seems to work better for me at this time
Menthol
Level 14
I am using 1 and 4 as per manual, I have an Intel 750 in slot 6 which I believe is off the chipset and doesn't affect the other slots, but I may be wrong, I will remove that drive and test again this weekend
57553
Menthol
Level 14
Sorry to hear that, I turned off the bottom pcie slot that my Intel pcie drive is in and my to GPU's worked as intended in sli
