Results 1 to 6 of 6
    ROG Enthusiast Array
    Jun 2014
    28
    G752VY: left fan is hot as hell
    i cant use this laptop on lap because its get really hot on near the audio ports and left fan,
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    There is a known issue to some with the audio jack getting hot. Use the search feature and it will lead you to what to do about it.
    Left Fan is the CPU area.
    This machine wasn't really meant to be used on your lap, nor would I use it on my lap or any non hard surface. Its not actually classified as a laptop, its a notebook.
    Nothing personal brother but you seem to be quite new to the world of high power portable machines. They all have short battery run time and they all heat up to some extent and should not be placed on your lap, bed, sofa, etc unless you use a hard device such as a cooling pad.http://www.amazon.com/Cooler-Master-...aptoprunner-20
    Aug 2015
    48
    from what tells your program, I understand that the temperature at 66 ° is not the current one, but a maximum peak reached using the pc, and indeed above it says Max tries to use instead AIDA64
    Jun 2014
    28
    Hey,
    Yes i am new to high power portable machines. i am a desktop guy.
    about an hour ago i have received Hover X+ LapDesk
    Jun 2014
    28
    Hover X+ lapdesk is way too heavy. can you guys suggest anything else?
    ROG Guru: Yellow Belt Array kidfromhell's Avatar
    Dec 2013
    141
    Quote Originally Posted by k1ng440 View Post
    This is what I use: It fits the G752 perfectly (have been using it since the G750 series) with ample space for a mouse. I know that this isn't a one that has holes beneath to promote airflow, but it is pretty good at what it does.
    The legs can be folded to use it on a lap, but the result can vary. I find it okay to use it that way, but some might find it uncomfortable. Also the desk can be tilted in 3 angles.
