Asus GTX 970 Strix 4GB OC signal problem
Zwoik
Hi!
I recently bought the Asus 970 strix oc and I have a common issue but I can't solve. When I start a game, in 3, 4 minutes aprox. (depending the game requirements) appears black screen and no signal message.
I reinstalled the drivers, tried with old drivers and updated, clean install, tried without Gforce Xperience (only drivers and physx). I restarted and Updated BIOS, changed the PCI-e slot (16X_2), changed HDMI cable, tried with DVI, tried in other monitor. I changed the 3D power config to best performance in Nvidia config, changed the overclock to -105, with GPUTweak and MSI afterburner... and the same result: No signal
OS: Windows 10 x64 (updated)
CPU: intel i7 950
Memory: 16GB ram
Motherboard: Asus Sabertooth x58 (BIOS updated)
PSU: Thermaltake 750W
Thanks for your help!
St_Johann
Had the same problem with 970 cards. Fans do not start sometimes, it gets hot 91.celius and turns off.
I think the problem was GPU Tweak!
Did you used:
ASUS GPUTweakII RemoveTool
ASUS GPU Tweak II Remove Tool could help you uninstall GPU Tweak II completely before update to a new version/msi afterburner
I use now GPU TweakII V1.0.3.6 and it works great GPU 1400 and memory at 7500MHz
https://rog.asus.com/forum/showthread.php?83798-980-Strix-makes-computer-restart-when-under-load-RMA...
https://rog.asus.com/forum/showthread.php?84027-Problem-with-GPU-Tweak-2-GTX-980TI-and-PG348Q-NEED-H...!
https://rog.asus.com/forum/showthread.php?84464-GP-Tweak-2-monitor-issue
