Help! I REMOVED ATHEROS BY MISTAKE!
Retired
Not applicable
Trying to remove the potential source for some unwanted quirks in my machine i removed the Atheros programs one of which was the driver. I have an Eee PC netbook with windows xp. what do i do now?
xeromist
You'll want to go to the following link, select your EEE PC from the drop down boxes and then download the driver file to a USB flash drive. Then you just plug the flash drive into your netbook and install it. Note that if you don't have a program to unzip files on your netbook then you'll want to unzip it first and put the unpacked files onto the flash drive.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Retired
Not applicable
which notebook was this on?
V2-V3
If you continue to have problems with your Atheros software you can the drivers without the Atheros Wireless manager and set windows to manage your wirless networks.
