Results 1 to 5 of 5
    New ROGer Array
    May 2016
    1
    g752vy and using g-sync on external monitor?
    Hello good people,i plan to buy ASUS VG248QE monitor and use it with my laptop...i need few questions answered..
    Since laptop have g-sync and monitor is g-sync capable..do i automaticlly get g-sync on monitor when i plug it to laptop or it doesn't function that way..if you get what i want to say.
    Do i need to buy that g-sync thingy for monitor(which cost 200$ i believe)in order it to work?
    What type of cable should i use to connect monitor to laptop...displayport??I heard that you should use 1.2..i dont think i can get that version in my country..
    Thanks in advance.
    ROG Guru: Yellow Belt Array kidfromhell's Avatar
    Dec 2013
    141
    Yes, monitor need to have G-SYNC separately in order to work. The inbuilt G-SYNC works ONLY on the notebook display. In that case, yes you SHOULD spend that extra $200 to get a monitor with G-SYNC.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    i see nowhere that lists that monitor as being G Sync capable.
    Im just bought an ASUS PG279Q monitor that is G Sync capable and has a 165hz refresh rate. For it to work correctly with the laptop I had to buy a mini display port to full display port cable. HDMI would not recognize the G Sync nor would it go past 60Hz refresh rate. I ordered the cable from Amazon, nothing special but no one seems to stock them. Best Buy Dork Sqaud tried to feed me some line of crap about Display port being slower and they are going away blah blah blah, I was like dude, have you seen the newest GTX 1080 card? Before you go spouting off your should know what you are talking about first. It has 3 display port connections for 3 monitor surround, 1 HDMI and 1 DVI-D.
    ROG Guru: Orange Belt Array
    May 2011
    28
    392
    Justin is correct. Looks like that's a 144Hz monitor, but it doesn't state it supports G-SYNC anywhere. It just looks like a high refresh rate monitor. As far as I know a G-SYNC monitor has to be labeled as such to support it specifically.
    https://www.asus.com/us/Monitors/VG248QE/
    (ROG has simply become too expensive compared to the competition with same specs... )
    MSI GE75 Raider 10SGS - i7 10750H - RTX 2080 Super - 32GB Ram - 1TB WD NVMe - 2TB 960 EVO - 300Hz 17inch Display
    RETIRED: ALIENWARE R17 R5 - i7 8750H - GTX 1070 @ 1.9Ghz - 16GB DDR4 - NVMe 970 EVO 1TB - SSD 960 EVO 1TB
    SOLD: ASUS G703VI-XH74K, RETIRED: ASUS G752VY-DH72, RETIRED: ASUS G750JH DB71 , RETIRED:ASUS G74Sx DH72
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,857
    As a contrast here is my monitor spec page that specifically says G Sync.
    https://www.asus.com/us/Monitors/ROG-SWIFT-PG279Q/
    Of course you are looking at your $250 monitor Vs my $800 monitor.
