Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    ROG Enthusiast Array kryptekpcmodz PC Specs
    MotherboardAsus Maximus Formula VI
    ProcessorIntel i5 4670K
    Memory (part number)Corsair Dominator Platinum 2x4GB 1600mhz
    Graphics Card #1Asus GTX 770 DCUII 2GB
    Storage #1Samsung 840 PRO 120GB SSD
    Storage #2Seagate Barracud 1TB 7200rpm
    CPU CoolerCustom water cooling
    CaseCorsair 600T
    Power SupplyCorsair HX650
    Jul 2015
    65
    [Build Log] Project ASTRAY - COMPLETED
    Hey guys It's me again! I started this project mod last May 10, 2016. I'm making a build for cooler master case modding competition, this time the past project called Project 45Deg will on pause for a while. I just need to concentrate for this new project and I got only few days to finish it. And it is my first time to join the event, my build is a little inspired with gundam toys. Astray, I caught that name on a gundam toy. And I know that I got only a few weeks to finish this build, I hope that I can make it to the finals.
    So the build is now completed, you can see my idea for modding the case. Feel free to comment and suggest.
    The final photos are on Page 2
    Here are the specs.
    Processor: Intel i5 6600k
    Motherboard: Asus Maximus VIII Ranger Z170
    Memory modules: Avexir Red Tesla 4x4GB 2666mhz
    GPU: Asus GTX 970 Strix DCUII
    Case: Cooler Master MasterCase 5 Pro
    PSU: Thermaltake DPS G Platinum 1200watts
    SSD: OCZ Trion 150 240gb
    Custom Water Cooling:
    Radiator: Bitspower Leviathan Xtreme 360
    Fans: Thermaltake Riing 12 White
    Pump: Bitspower D5 MOD Package (Black POM TOP S + MOD Kit V2 Matt Black)
    Tubes: Bitspower None Chamfer Brass Link Tubing OD12MM Shining Silver
    CPU Block: Bitspower CPU Block Summit EF ICE Black (Intel, Acrylic)
    GPU Block: Bitspower VG-NGTX970ADIIS Acrylic Top With Stainless Panel (Clear)
    Reservoir: Bitspower Water Tank Z-Multi 200 V2 (Clear Body & POM Version)
    Fittings: Bitspower G1/4" Matt Black Enhance Multi-Link For OD 12MM
    First of all I would like to say a huge thanks to all of my sponsors who make this possible..
    - ASUS Philippines
    - Avexir
    - OCZ
    - Cooler Master Philippines
    - Bitspower
    - PinoyRigz
    - Baguio Modders Inc.
    So before we proceed to modding, let me take a quick post of the chassis.
    CaseCorsair 600T
    Jul 2015
    65
    So this is my initial sketch for the build, I'll add more details once it almost done. I know some of the concept are same with my on going project 45deg.
    Disassembling the chassis to make a inverted motherboard position.
    CaseCorsair 600T
    Jul 2015
    65
    The motherboard, gpu and memory modules that I will be using to the build.
    Special thanks to ASUS Philippines and Avexir for letting me use there products
    note: *some of these photos are taken from my previous project 45deg*
    CaseCorsair 600T
    Jul 2015
    65
    Cont....
    CaseCorsair 600T
    Jul 2015
    65
    Ok, I just finished the motherboard bracket.
    Next, I will cut the back panel..
    Cutting the back panel cover... I used 4.5mm acrylic sheet.
    CaseCorsair 600T
    Jul 2015
    65
    Test fit...!
    Start to sleeve these cables, I'll make it all black!
    I used 3mm black sleeve from PinoyRIGZ.
  7. #7
    CaseCorsair 600T
    Jul 2015
    65
    I just need to cut these grills and replace with a see through acrylic sheet.
  8. #8
    CaseCorsair 600T
    Jul 2015
    65
    layouting....
    Hey guys! I will paint these motherboard heatsinks into white.
    I just removed the ROG aluminum logo
    Goodbye labels
    Painted...
    Now I finished the north bridge heatsinks, why just only the north bridge I've done today? because I need to buy some piece of acrylic sheet for the south bridge logo.
    Now here is the result. I made some custom vinyl stickers for detailing and not get bored with the plain paint.
    Stay tuned!
  9. #9
    CaseCorsair 600T
    Jul 2015
    65
    Will use this Intel i5 6600k processor for my build..
    And I would like to thank to OCZ Storage Solutions for giving and supporting my project.
  10. #10
    CaseCorsair 600T
    Jul 2015
    65
    I got some little update for my front panel and fans.. I put a fan guard and the I made a custom Astray logo. Hope you'll like it.
    Painted with primer spray can..
