Results 1 to 5 of 5
    New ROGer Array
    Nov 2015
    2
    Cooling pad for asus g752vy
    Hello. I am looking for a laptop cooling pad for my Asus G752VY. Can you guys suggest some good ones or tell me if the laptop even needs one?
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    Did you check temperatures on GPU-CPU and you need cooler?
    Maybe this...with replacable 120mm fans.
    http://gaming.coolermaster.com/en/pr...rs/sf19v2usb3/
    But you should google and search little what ROG laptop owners think about them.
    That's for up to 19" laptops, USB 2.0 and USB 3.0 version, there are and version 17.
    New ROGer Array
    Nov 2015
    2
    cooling pad for asus g752VY-RH71
    Quote Originally Posted by Vlada011 View Post
    My g752VY shows cpu and gpu temp of 50 and 51 degrees celcius, that too after 2 hours of gaming. Is it normal and should i go for a cooling pad?
    ROG Guru: Yellow Belt Array kidfromhell's Avatar
    Dec 2013
    141
    Quote Originally Posted by Arslan View Post
    That is VERY normal. It's not even close to the safe 80C limit. You don't need one unless you wanna carry one with you everywhere though. Heck, mine reaches 55 to 60C when watching videos on Chrome. You temps are nothing. Don't worry
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    Yes, your temps are perfect.
    I ask because of that did you check temperatures because they build much better cooling in G752...
    Space for air is much bigger than on previous version G751.
