Results 1 to 6 of 6
    New ROGer Array MeisterBroseidon PC Specs
    MotherboardASUS ROG Maximus VIII Hero Alpha
    ProcessorIntel i7 6700k
    Memory (part number)G. Skill Trident Z 3200 MHz 2x16 (F4-3200C14D-32GTZ)
    Graphics Card #1MSI Geforce GTX 970 Gaming 4G
    MonitorBenQ 27" 1ms
    Storage #1Samsung 850 Pro 128gb 2.5" SSD
    Storage #2Western Digital 7200rpm 1TB
    CPU CoolerNoctua NH-U14S
    CaseCooler Master HAF 932
    Power SupplyEVGA SuperNova P2 750w
    Keyboard Logitech G15
    Mouse Razed Naga
    Headset Logitech G930
    OS Windows 10
    Jun 2016
    3
    Recommendations on RGB Strips for RGB Headers on Hero Alpha?
    Hey everyone. First post here....
    I've never actually bought RGB strips before and I was wondering if anyone would mind recommending some strips for this motherboard specifically. I would like to ensure that they are no cheapo lights.... There are a ton on Newegg and I was just looking for a bit of help on this particular issue. Silly question I know... but I appreciate your help in advance!
    -Chris
    MonitorBenQ 27" 1ms
    Mouse Razed Naga
    OS Windows 10
    Jun 2016
    3
    Thanks a ton, Chino. This is exactly what I was looking for. I already ordered them.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hi MeisterBroseidon
    Here's a 5050 RGB strip with 4-pin RGB connector and can select a white or black finish, for maximum brightness keep it under 2m (6 foot).
    https://www.superbrightleds.com/more...onnector/1470/
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,464
    I think Phanteks make some some LED Strip 1m and 2m long, and RGB LED adapter ASUS AURA Ready.
    You can check on their site...
    http://www.phanteks.com/PH-CB_RGB4P.html
    http://www.phanteks.com/PH-LEDKT.html
    Maybe someone know some better options but these look OK to me if someone have new ASUS ROG motherboard.
    This will fit and on Rampage V 10TH Edition.
    ROG Member Array
    Jan 2016
    16
    If you do not like waiting and have a nearby Lowes go there they have a spot for accent lighting with LED strips. Specifically this kit http://www.ebay.com/itm/like/1722306...&ul_noapp=true
    I checked the Lowes website and it is not listed but I was shocked to see they keep a supply of it. It should be just a little over 30 bucks but it comes with two 2ft lengths and works just fine with my Alpha board! Check the packaging before buying because I got a couple kits for the boys bedrooms in general and one box was missing the remote.
Tags for this Thread
