Results 1 to 9 of 9
    ROG Guru: White Belt Array orcinus PC Specs
    orcinus PC Specs
    MotherboardRampage V Extreme 3504
    Processori7-5960X @ 4.585GHz strap 125, BCLK 131
    Memory (part number)F4-2800C16Q-32GRR@13-13-13-33-CR1-BCLK 131,
    Graphics Card #1TITAN Xp
    Graphics Card #2TITAN Xp
    Sound CardAsus Xonar Essence STX
    MonitorDell UP2715K
    Storage #1SM 960 Pro 2TB RADI1
    Storage #2SM 960 Pro 2TB RAID1
    CPU CoolerEKWB custom 2x480mm + 1x560mm
    CaseCaseLabs Magnum STH10
    Power SupplyCorsair AX1500i
    Keyboard Logitech G710+
    Mouse Logitech G900
    Headset Sennheiser PXC550
    OS Windows 10 Enterprise 64 1701
    Network RouterAsus AC88U
    Oct 2014
    106
    USB devices randomly self turn off and on back again...
    I'm not sure, but I suspect this could have something to do with the power supply of USB ports. I have no idea why this happens, but randomly my USB devices just go offline and then back online, like these were unplugged and plugged in back again.
    This happens more often during gaming (higher load?) but sometimes for no apparent reason.
    Is there a setting where I can check what is going on? Is this a board malfunction? What may be the problem?
    Also, this more often happens with my keyboard, but sometimes with my camera (Logitech) or a microphone (Yeti) if I'm in a conference call...
    Has anyone encountered this problem before?
    System: Windows 10 x64
    BIOS: 3101
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Is there a voltage supply I can set higher for all the USB hubs?
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,456
    You have best possible PSU on the world.
    Problem only could be in motherboard. Did you tried with some older driver for controllers, or to change USB Ports?
    From ASMedia to Intel or from Intel to ASMedia.
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    I've tried all I could. It started happening only recently, but nothing has changed. It affects only and only USB. I'd suspect the board is the problem, but I'm so annoyed by even the fact I'd have to RMA it. I can't be without a machine for a day, let alone weeks.
    New ROGer Array
    Apr 2016
    2
    Quote Originally Posted by orcinus View Post
    Mine has been doing this for months and I can't figure it out. About to just find a different board all together....
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Quote Originally Posted by Tschelle10 View Post
    What devices? What Windows? Can you please give more details, it may help.
    I'm not really happy about the option to pull my machine out and assemble it again..
  7. #7
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Anyone from Asus?
  8. #8
    New ROGer Array
    Mar 2014
    2
    Fixed mine
    I was having the same issue i downloaded asmedia package b on this page to update my drivers and have not had it happen to me since. It was especially bad with my Razer Mamba as well as my Vive but no issues in the last 2 weeks using these drivers i hope it helps.
    http://www.win-raid.com/t834f25-USB-...nd-modded.html
  9. #9
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Quote Originally Posted by RazerBaird View Post
    I've fallen back to BIOS 1902 and no problems so far. Of course, not a solution, but... - i was using official drivers from Asus web.
