06-18-2016 02:40 PM - last edited on 03-06-2024 02:07 AM by ROGBot
06-18-2016 11:28 PM
06-18-2016 11:52 PM
06-19-2016 07:43 AM
stathis221 wrote:
Dont forget the nvme drivers from samung site,download the latest.
06-19-2016 07:43 AM
MeanMachine wrote:
Hi said53 🙂
Only use fast boot once your system is configured correctly in all aspects.
Go to your Bios>Boot Menu>Enable Fast Boot.
>USB Support> Choose whats good for you.
> PS2 devices> disable if using USB peripherals
>Network stack driver>disable.
Next boot after AC power loss>your choice
Boot Logo display>disable
Post report>0-2 seconds
Ensure boot priority to your SSD and disable other Legacy options to HDD if you don't have them.
Check CSM is enabled.
Check AHCI for SATA
Check: Boot Device Control: UEFI
Boot from M.2 device.
Disable Hot Plug on all ports except those set for eSATA.
Go to>Advanced menu
CPU configuration>Boot performance mode: Turbo
SATA configuration: AHCI.
Also here is a good tutorial by JJ : https://www.youtube.com/watch?v=amwujljr7pY
Please report your results:)
06-19-2016 07:47 AM
06-28-2016 06:21 PM
06-29-2016 03:28 AM
said53 wrote:
Sorry for replay probably to late MeanMachine. Work and Gym really takes time away from PC. But any ways I reinstalled my windows and used guide for bios tweaks and wow PC boot time somewhere 15 to 18 sec and shout down only 2 sec!!
