Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    ROG Guru: Yellow Belt Array Lynkdev PC Specs
    Lynkdev PC Specs
    MotherboardRIVE
    Processor5960x
    Memory (part number)G.Skill 32gb 2133 F4-2133C15Q-32GRR
    Graphics Card #1EVGA SC TITAN X
    Graphics Card #2EVGA SC TITAN X
    Sound Cardonboard HD
    MonitorAcer Predator 34-inch
    Storage #12x 840 PRO 256gb RAID 0
    Storage #2850 pro 512 ssd
    CPU CoolerUnderwater
    CaseCase Labs TH10
    Power SupplyAX1200i
    Keyboard Razer Chroma
    Mouse Razer Chroma
    Headset Razer Chroma
    OS 10 pro x64
    Apr 2013
    140
    Best displayport cable for Acer Predator X34?
    Looking for a 10ft cable that wont give me any issues running from my titan x sli setup to this monitor please. I was looking on amazon and cable matters brand seems worrisome with random issues.
    I'm looking for a cable that's 1.2 and can handle the 3440 res at 100hz.
    ROG Guru: Orange Belt Array
    Dec 2011
    24
    293
    Try Cyberguys - www.cyberguys.com
    Lian-Li PC-A77F Full Tower case
    PC Power & Cooling Turbo-Cool 1200 ATX12V & EPS12V PSU
    ASUS Rampage IV Extreme LGA 2011 X79
    Intel Core i7-3960X 3.31 LGA 2011 CPU
    Intel RTS2011LC Liquid Cooling Solution
    Kingston KHX24C11T3K4/32X (quad 32Gb memory kit) 2 each
    ASUS Radeon HD7970 DirectCUII 3Gb GDDR5 PCIe 3.0 x16 Video Card (two in CrossfireX Mode)
    Western Digital Cavier Black 2Tb SATA III 6.0GB/S
    OCZ Technologies Vertex 4 SATAIII 6Gb/s 512Gb SSD
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Lynkdev PC Specs
    MotherboardRIVE
    Processor5960x
    CaseCase Labs TH10
    Power SupplyAX1200i
    Mouse Razer Chroma
    OS 10 pro x64
    Apr 2013
    140
    thanks guys, ill check them out!
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    the shorter the bether.
    ROG Member Array osiris316 PC Specs
    osiris316 PC Specs
    MotherboardAsus ROG Maximus VIII Hero
    ProcessorIntel Core i7-6700K 8M Skylake
    Memory (part number)G.SKILL TridentZ Series 16GB (2 x 8GB) F4-3000C15D-16GTZ
    Graphics Card #1SAPPHIRE NITRO Radeon R9 Fury 4GB 4096-Bit HBM TRI-X OC
    MonitorASUS VG248QE Black 24"
    Storage #1SAMSUNG 950 PRO M.2 256GB PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V5P256BW
    Storage #2WD Black 1TB 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD1003FZEX
    CPU CoolerNoctua NH-U12S 120x120x25 ( NF-F12 PWM) Two fan
    CaseAntec Twelve Hundred V3
    Power SupplyEVGA 220-T2-1000-X1
    Keyboard Logitech G810 Orion Spectrum RGB
    Mouse Logitech G602
    OS Microsoft Windows 10 Pro 64-bit
    May 2016
    14
    Hi Lynkdev,
    I got a tip from a cable junky friend that does a lot of home entertainment room creations. I'm sure he told me they will even make custom cables to your specs, he sent me here for my Dual Link DVI-D Cable. I needed this link for the 144Hz refresh on my VG248QE monitor. I chose DVI over DP based on reviews for my particular setup.
    Best regards,
    www.monoprice.com
    http://www.monoprice.com/product?c_i...seq=1&format=2
  7. #7
    Lynkdev PC Specs
    MotherboardRIVE
    Processor5960x
    CaseCase Labs TH10
    Power SupplyAX1200i
    Mouse Razer Chroma
    OS 10 pro x64
    Apr 2013
    140
    Quote Originally Posted by osiris316 View Post
    Hi Lynkdev,
    Best regards,
    www.monoprice.com
    thanks Osiris, are you saying DVI-D is better over DP or just for your setup? I have two titan x's in SLI feeding my Acer Predator X34 which is running at 100hz max. Would I lose anything swapping to DVI-D?
  8. #8
    ROG Guru: Brown Belt Array sk2play's Avatar
    Dec 2013
    139
    1,058
    Quote Originally Posted by Arne Saknussemm View Post
    Ouch on the price, but I bit on a 10ft DP 24GWD for dvigear just now to see if it resolves my issue.
    I have a Accell 10ft DP one currently which is ok, it just gives me a black screen about once or twice a month coming out of sleep mode. Fix is just to turn on/off the LCD but that is a drag on my clean ride, if you know what I mean.
    Corsair 500R Case, H110 Hydro, 1200AX PSU, Asus Maximus Hero VI MB, Intel 4770K CPU, Gigabyte GPU GV-N98TWF3OC-6GD, G-Skill Trident 2400MHz 32GB, Crucial M500 960GB SSD, Seagate 6TB HDD x2, Creative SBZ to Denon AVR-4311ci - Infinity Primus 5.1 w/Klipsch Sub XW-300d, HP ZR30w 30" S-IPS LCD, W10 64bit
  9. #9
    ROG Enthusiast Array
    Jan 2016
    32
    Can't use gsync with dvi-d though correct?
    Sent from my SM-N920V using Tapatalk
  10. #10
    osiris316 PC Specs
    Mouse Logitech G602
    May 2016
    14
    Hi Lynkdev,
    Wow, I guess I should have learned more about your gear. That's a very nice Monitor. All good. If my quick research is correct, your Acer Predator X34 only has two inputs. 1 x HDMI and 1 x DP. I'm not a tech guru. I have yet to wade into the pond of SLI or Crossfire setups. I'm not sure about cable adapters used between the GPU cards output and Monitor input. Put simply, The monitor I have listed in my forum profile will only achieve 144Hz refresh using a DVI cable. So yes this is for my specific setup/gear.
    If I had not read about the fact that for the ASUS VG248QE monitor and the HDMI 60Hz cap, I would have never known, to really get that 144Hz refresh I need to use the DVI DL connection. Again. For my specific setup.
    Links that got me there are linked for you as well. This current build I have is replacing my rig from six years ago. Back in the glory days of the AMD Phenom II Black Edition Six cores. And it's still alive and well.
    http://www.newegg.com/Product/Produc...82E16813131646
    I had to relearn all of this tech info. Only linking it because it really helped me out to remember the basics most take for granted. Regarding the GPU and Monitor connection cabling options.
    Well met,
    Osiris
    https://en.wikipedia.org/wiki/Digital_Visual_Interface
    https://en.wikipedia.org/wiki/HDMI
    https://en.wikipedia.org/wiki/DisplayPort
