I've been having this intermittent problem it hasn't been effected by bios updates, clearing cmos or any motherboard settings. I can have everything at factory default, xmp, overclocked stable at 3.9, 4.0, 4.5 with various voltages and settings. Nothing eliminates it.
Everything will run fine and pass memtest, intelburntest, realbench, superpi, whatever you want to throw at it. Not a problem.
After a while (ranges from hours to days) the fans will stop working and freeze at whatever speed they were running. Ai Suite will show two dots on it's fan graphs, a transparent one where the fan should be, and a solid (normal) one where the fans actually are. In addition no utility will be able to read T_Sensor 2 or T_Sensor 3. At this point everything is still stable, as long as i manually adjust fan speeds as necessary to keep things cool.
Sometimes this happens while idle, other times under full load, and everywhere in between.
If I restart at this point it hangs with POST code b1, restarting further hangs with POST code 76.
If I turn off the PSU and wait for the lights to turn off then turn it on again it will say "Overclock Failed" etc. even with system defaults, and after confirming settings everything will work fine again, until it happens again.
Any ideas?
Thanks,
-Kurt
