Results 1 to 2 of 2
    New ROGer Array
    Jun 2016
    3
    Lightbulb Will Installing Multiple Tb Drives in my G751 Cause Any Power Issues?
    I plan on putting 3 separate 1Tb drives in my G751. I'm planning on using a 1Tb M.2, 1Tb SSD, and replacing the disk drive with a 1Tb mechanical drive. Will I encounter issues with the power supply? when I put 3 1Tb mechanical drives in my tower I had to upgrade the power supply. Do large SSDs have larger power requirements?
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,563
    u will be fine , I have 3 drives in my G751 no issues
Tags for this Thread
