Results 1 to 8 of 8
    ROG Enthusiast Array
    Mar 2015
    33
    GTX 1080/1070 Temps on your G20
    To anyone playing any extensive games with their G20 running the these card. Can you post your temp results? Screenshot of the game and temp is appreciated.
    Would like to know if there's a huge different with airflow with 1080/1070 on a G20. Thanks!
    ROG Member Array
    May 2016
    8
    1080 user here.
    In intense games like Witcher3 & assassin's creed syndicate 1440p i get around 80 degree (with evga precision x & custom fan control on aggressive)
    im thinking about getting a laptop cooling pad just to try out if it helps. (to my understanding the Asus G20 blows the air for underneath)
    something like this
    ROG Guru: Yellow Belt Array Welsh Whoopee's Avatar
    Jan 2016
    18
    243
    yeah it sucks the air from the bottom of the case and takes it to the top, its a great idea on that
    YOUTUBE CHANNEL @ http://bit.ly/2LNo1dI
    ASUS ROG G20 PLAYLIST @ http://bit.ly/2R9njXC
    Mar 2015
    33
    Quote Originally Posted by WarpGuN View Post
    1080 user here.
    something like this
    Would like to hear if there's a difference with the laptop cooling pad. Thanks for commenting.
    ROG Member Array
    May 2016
    8
    Quote Originally Posted by Gengaku View Post
    It didn't help so i returned the laptop cooler to the store.
    ROG Enthusiast Array six4bravo's Avatar
    May 2016
    44
    58
    Yeah i tried some coolerguys 80mm dual fans with them blowing up into the case. Didn't help at all. Now working on a simple water cooling solution for my G20CB, hopefully will have enough room for a water cooled gtx 1070 later too. The air channels in the case are so darn tiny. On my mildly overclocked gtx 970, I'm at 75*C and averaging 100fps in BF4.
  7. #7
    Mar 2015
    33
    Thanks again for letting us know that it doesn't help.
    Quote Originally Posted by six4bravo View Post
    Thanks for the feed back. Btw just saw your thread! https://rog.asus.com/forum/showthrea...ooling-project.
    Can't wait to see the final result of your project i really like the idea. Hope everything goes well. Good luck
  8. #8
    May 2016
    44
    58
    Thanks. Still cleaning up the build, but fired it up last night with the corsair H60 and basically cut the CPU temps in half, ~17C idle and ~47C under load. Details are in my thread.
Tags for this Thread
