06-28-2016 08:45 PM - last edited on 03-06-2024 02:07 AM by ROGBot
06-29-2016 11:41 AM
06-29-2016 07:34 PM
JustinThyme wrote:
http://rog.asus.com/forum/showthread.php?38102-G73SW-and-770M-upgrade-is-possible
770M obviously works.
Also another member did a 670MX in a G75VW
http://rog.asus.com/forum/showthread.php?84450-Replacing-GeForce-GTX-660M-in-a-G75VW
If it can be done @Dreamonic would be able to tell you, hit him up.
06-30-2016 07:29 PM
07-01-2016 10:01 AM
07-02-2016 07:57 AM
Dreamonic wrote:
That is correct and some ASUS VBIOS do not use the MXM signature structure (rather OROM instead) unlike all the standard MXM GPUs. Starting from the G750 GPUs and up, ASUS has been using the Winbond 25X40 8-pin SOIC onboard, which if you follow along here: https://rog.asus.com/forum/showthread.php?85716-G75VW-Deep-Bios-Help and https://rog.asus.com/forum/showthread.php?85749-Asus-G75VW-BBK5-With-Upgraded-GTX-780M-GPU-Success! you can read how there are ways to get around it and use the OROM (once inserted) instead. Mileage will definitely vary with each model, GPU and VBIOS version. The stages of that mod was very close to being finalized but currently not.
Regarding your GPU upgrade, it would be similar process but most likely your heat-plate, heatsink assembly would need to be swapped over with the proper heat-plate for the 670M instead, as your 460M heat-plate doesn't look like it makes contact with the VRM and VRAM on the 670M.
Also, in the ME FW you can change the port configuration to allow the VBIOS to be read directly onboard the GPU as well (preventing instructions to see OROM) with adding the VSCC (with chip id) that your particular W25X40 PN SOIC uses, but it's been a hit and miss using that method. You also would be required to do a full BIOS dump and have modified descriptor regions (unlocked) followed with the BIOS locks disabled so you can perform read/write to all regions using FPT for testing any troubleshooting changes out along the way (hardware programmer required anyway).
Seeing as how @jmhdj successfully did this kind of modification for this particular model of notebook and you're in contact with him already, you should have your answers.
