Port Plugs to prevent dust buildup? - G752VY
PeteGeek
Hey ROG community
Hoping someone can help me out. My old G74SX had an issue with dust getting into the ports and I'd like to avoid that this time around with my new G752VY.
Does anyone know of a port plug kit that would suit my needs?
Would be nice if ASUS would include such a kit in the box for future releases. A $1.00 kit of silicone port plugs would be nice after dropping that kind of cash on a high end laptop 🙂
5 REPLIES 5
Clintlgm
Level 14
Yes there are rubber plugs in the dust evacuation ports, you would take them out while using and replace them when not using the notebook. Lots of people threw them out while unpacking there notebooks, not knowing what they were.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
ll_r1d0_ll
PeteGeek wrote:
Hey ROG community
there you go http://www.aliexpress.com/item/Laptop-Dustproof-Silicone-cover-plug-For-ASUS-G752-G752VT-G752VL-G752...
Not only are the items in the link NOT the topic of conversation anyone who even thinks about using the vendor in the link needs to have thier heads examined thoroughly, or better yet, just send the money for that order to me instead. I will put it to good use and not send you anything for it either.
Its obvious that any review that is actually good is done by them or someone they paid to do it.
https://www.sitejabber.com/reviews/www.aliexpress.com
Thanks. That's precisely what I was after.
I did find other kits but they didn't have all the plugs for all ports.
nemerdekel
You are NOT I repeat NOT supposed to plug in your ports, they are used as air intakes!!!!!!!!
Laptop: G751JL
Processor: i7-4750HQ
Graphics Card: GTX 965M
Memory: 8 GB Samsung (stock)
Storage #1: Samsung 850 EVO 250gb
Storage #2: 1 TB 7200 rpm (stock)
OS: Windows 10 x64
