Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
    ROG Junior Member Array
    Jan 2015
    3
    ROG SPATHA charging dock issue
    Hello,
    I have received today my ASUS ROG SPATHA mouse. All is running fine while using the mouse. I installed armory and it directly updated firmware for both dock and mouse.
    After i played with the lights for a good while, programmed my buttons and tested a few games, i placed the mouse in the dock for charging.
    While positioned in the dock, the light on the mouse is continuously going flashing from green to red (color that I've set for use mode). I watched a few reviews online and noticed that in some of them the color on the mouse zones is always green while the mouse is docked.
    I initially thought it is a connection issue and tried to dock the mouse as it was turned off .. every time i dock the mouse the light turns on which tells me that it is charging through the dock. In armory the battery went to 100% after a while so that also confirms that it's charging.
    Does anyone else have this issue ? Is this a known issue ? Do i have a technical problem with my mouse ?
    Thank you in advance for the help !
    ROG Member Array
    Nov 2012
    9
    ROG Spatha dock problem
    I have this problem. The dock does not work after the latest update. The mouse works fine on wired mode but nothing on wireless mode. I'm going to try and find a solution here..
    http://thenitwitts.enjin.com/forum/m...wforum/5250475
    I do reviews and will do a fixit post for this. The dock just doesn't seem to activate. Put the wired mouse on and it activates. Take the plug out of the mouse and all dead, both mouse and dock, very odd.
    Necessitor.
    ROG Member Array
    Nov 2012
    9
    Ok, my solution was simply sequence of actions. So I unplugged and turned off the mouse at the base, then plugged the dock in, then turned the mouse on at the base. This is'nt explained anyway really. I'll have a look at your specific problem and try for an answer which will be in the review I've done. Also I'll post here for you. Great mouse btw, love it.
    Ex-employee Array
    Jun 2020
    108
    2,154
    I have reported this issue over to our peripheral team and they're looking into this
    ROG Member Array
    Jun 2014
    9
    Quote Originally Posted by Bahz View Post
    I also started getting problems with the dock.. TOday for example it seems dead.. well lights work when u restart computer. a purple light for one second or so but then it is not working. tried new USB ports and everything..
    So much problems with this product so far.. hope they get fixed very soon..
    EDIT: fixed now after removing USB in the dock and leaving it off a little. then put usb back in to dock.
    weird it did not fix itself by turning off computer, opening asus software, or plugging out and changing USB port in PC. it has to be unplugged by the DOCK and not the PC to start working.. very weird..
    Ex-employee Array
    Jun 2020
    108
    2,154
    Received update from our peripherals team that they're working on new version to fix this
  7. #7
    ROG Member Array vulcanmist PC Specs
    vulcanmist PC Specs
    Laptop (Model)ROG Zephyrus G14
    MotherboardROG Crosshair VIII Impact
    ProcessorAMD Ryzen R9 3900X
    Memory (part number)AX4U413338G19J-DT60
    Graphics Card #1TUF Gaming RTX 3080 10G
    MonitorROG Swift XG32VQR
    Storage #1Corsair MP600 1TB
    Storage #2Seagate FireCuda 2TB
    CaseLian Li TU150
    Power SupplyCorsair SF750
    Keyboard ROG Claymore
    Mouse ROG Gladius II
    Headset Drop x Senheisser HD 6xx
    Mouse Pad ROG Scabbard
    Headset/Speakers Audioengine A5+
    OS Windows 10 Pro
    Network RouterASUS Blue Cave
    Aug 2015
    6
    Angry ROG Spatha goes color crazy when charging!
    I have also experienced this problem. With the latest Spatha mouse driver, the color is supposed to be in green when full. However, it suddenly changes color in a split second. It's quite annoying knowing that it shouldn't be that way. Can you guys update it, or is there a way to downgrade the mouse firmware?
  8. #8
    Jan 2015
    3
    I actually found that there is nothing wrong with the mouse or dock.
    It is just a software / firmware issues
    So .. the mouse is supposed to pulse green while charging and battery is below 90% ... The mouse is not pulsing while battery is above 90%
    The issue is just visual in fact .. when the mouse goes from 89.9% to 90% it doesn't do that definitely .. so i suppose there is some kind of .01 .. 0.02 .. 0.0x fluctuation.
    Because of that fluctuation .. the color will shift from "pulsing green" to the color which is set by the user ... further on making us belive that the contact is imperfect.
    Until they fix it by some kind of software / firmware upgrade ... i'm inclined to suggest people not to worry .. there is nothing wrong .. it's just annoying .. but nothing wrong.!
  9. #9
    ROG Member Array
    Dec 2015
    13
    I have new driver: Software version: 1.01.19 and firmware version 1.57 . The docking not work. Wirless mode not work. When I press pairing to dock ... nothing, when I pres and hold - start blinking red. When I pres pairing to mouse - short blink and nothing.
  10. #10
    ROG Member Array
    Nov 2012
    6
    AEROPORTO Goole
    Quote Originally Posted by bateto_007 View Post
    For me the only solution for now is to unlug and replug the usb cable from the dock, and after that mouse starts to work in wireless mode. I need to do that every time I start my PC.
