Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,324
    When overclocking I try to keep my VCore to 1.30 What about the Cache? How high is that allowed to go on a Rampage Extreme with a 5930k?
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator Platinum SE 4x8 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p in a bootable VROC RAID 0 / Samsung 960 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Spatha
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  2. #12
    ROG Guru: Green Belt Array Qwinn PC Specs
    Qwinn PC Specs
    MotherboardRampage V Extreme - BIOS 3301
    Processor5930K @ 4.4 GHz Adaptive 1.27v / 4.2 Ghz cache Offset +0.27v / Input 1.92v / LLC7
    Memory (part number)G.Skill 32gb DDR4-2666Mhz 15-15-15-35-CR2 1.2v at XMP settings
    Graphics Card #1Gigabyte Gaming G1 980Ti OC to 1455Mhz Core 8000Mhz memory at Stock Voltage
    Graphics Card #2Gigabyte Gaming G1 980Ti SLI
    MonitorROG Swift PG278Q
    Storage #1Intel 750 PCIe 1.2TB
    Storage #2Sandisk Ultra II 960GB SSD
    CPU CoolerThermaltake Water 3.0 Ultimate (360" rad AIO)
    CaseThermalTake v71 Full Tower
    Power SupplyEVGA SuperNOVA 1200 P2
    Keyboard Saitek Eclipse II
    Mouse Razer A5090 Master of Destiny
    OS Windows 10 Professional 64 bit Build 10586
    Jul 2015
    46
    670
    I wouldn't ever go higher than 1.25 vcache on a 5930k, and in fact I keep mine at 1.21v for 24/7 use (gets me 4.2Ghz). The limited performance improvement you get from cache overclocking simply isn't worth the risk (or the additional overall heat) to go any higher.
  3. #13
    ROG Enthusiast Array Dkp1988 PC Specs
    Dkp1988 PC Specs
    Processori7 5820k
    Memory (part number)Corsair Vengence 2666 Mhz DDR4
    Graphics Card #1EVGA GTX 660
    Sound CardSound Blaster Z
    MonitorAsus Monitor 74 Hz
    Storage #1SSD Evo 250 gb
    Storage #21 TB WD HD
    CPU CoolerNoctua NH-D14
    CaseCooler Master Haf 932
    Power SupplyCorsair 850 watt silent
    Keyboard Corsair MX Silent
    Mouse Logitech G500s
    Headset Senheiser PC 350 SE
    Mouse Pad SteelSeries
    OS Windows 10 Pro
    Mar 2016
    45
    These are my temps idle at booting up into windows overclocked at 4.5 and core voltage at 1.3
    Motherboard 32 °C (90 °F)
    CPU 42 °C (108 °F)
    CPU Package 52 °C (126 °F)
    CPU #1 / Core #1 43 °C (109 °F)
    CPU #1 / Core #2 43 °C (109 °F)
    CPU #1 / Core #3 42 °C (108 °F)
    CPU #1 / Core #4 42 °C (108 °F)
    CPU #1 / Core #5 42 °C (108 °F)
    CPU #1 / Core #6 42 °C (108 °F)
    PCH 39 °C (102 °F)
    VRM 48 °C (118 °F)
    GPU Diode 37 °C (99 °F)
    WDC WD1002FAEX-00Y9A0 35 °C (95 °F)
    Samsung SSD 850 EVO 250GB 37 °C (99 °F)
    Do you think that I should re apply thermal paste or dont even bother?
  4. #14
    Dkp1988 PC Specs
    Processori7 5820k
    OS Windows 10 Pro
    Mar 2016
    45
  5. #15
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,387
    Your temps are "about" what I would expect for the ambient temp and air cooling. I say about....I would actually expect at stock that the idle temp be a couple of degrees lower so yeah...I would always recommend re-pasting and remounting if in doubt. Get a good paste like PK-1 and apply sparingly...check pattern in paste when you take off cooler...will show if you have put too much or too little...
    The temps you show for 4.5 show the cooler struggling to keep up for me...I would be very careful in watching temps stress testing...
