Results 1 to 1 of 1
    New ROGer Array
    Dec 2011
    1
    G53jw-a1 Video card problems.
    I just installed and reformatted to windows 7 ult 64 bit. I have all the neccesary drivers installed and newest graphic card update. I then downloaded GPU-z and noticed that my heat was off the roof. I hit 99 degrees. Does this mean my computer is defective or it is normal? I tested games like oblivion, saints row 3 and played on LOW settings and it still seems to cook.
    I played around with settings and thought it was the SSD all is fine
    think it is video card.
    Best alternative is to buy a laptop cooler? or RMA?
    let me know thanks.
