Results 1 to 2 of 2
    ROG Member Array
    Jul 2015
    21
    ROG G751JY and double external monitor
    Hi guys,
    I do have the laptop in the subject and I connected it to my TV using the HDMI port.
    I am planning on buying also a monitor and I noticed that there is a port, next to the HDMI one, that seems a micro HDMI so I was wondering if I can use the HDMI port to connect it to the TV and the micro HDMI to connect it to the monitor.
    Am I correct? If not, any suggestion?
    Thanks.
    New ROGer Array Genotabby PC Specs
    Genotabby PC Specs
    Laptop (Model)G751JY-T7368H
    MotherboardRampage VI Extreme
    Processori9-7900x
    Memory (part number)G.Skill 4x 16GB Trident Z RGB
    Graphics Card #1Strix GTX 1080TI OC
    Graphics Card #2Strix GTX 1080TI OC
    Sound Cardifi Nano iDSD BL
    MonitorAcer X34
    Storage #1Samsung 960 Pro, Samsung SM951
    Storage #2HGST 6TB, WD Black 4TB
    CPU CoolerNZXT Kraken X62
    CaseCoolermaster C700P
    Power SupplyCorsair AX1200i
    Keyboard Corsair K95 RGB Platinum
    Mouse Logitech MX Master 2S
    Headset Kingston Hyper X Cloud 2
    Mouse Pad Steel Series QCK
    Headset/Speakers AudioEngine HD6, Sennheiser HD6XX
    OS Win 10 Pro
    Network RouterAsus AC88U, AC68U
    Accessory #1 Coolermaster Cooling Bracket
    Accessory #2 Transcend SD Card Reader
    Accessory #3 Lexar SD Card Reader
    Aug 2015
    2
    The port beside it is a display port. However there have been reports of some issues from previous G751 models using HDMI and display port in which the mouse freezes. You can refer to these threads :https://rog.asus.com/forum/archive/i...p/t-54642.html
