Results 1 to 6 of 6
    ROG Enthusiast Array
    Jul 2012
    27
    Rampage V Edition 10 Onboard Sound vs Sound Blaster ZXR?
    What sound option would you choose?
    Regards,
    Lotek
    ROG Member Array
    Jun 2016
    8
    Quote Originally Posted by Lotek View Post
    Regards,
    Lotek
    ZXR is like night and day compared to the onboard junk when running a quality set of headphones. The onboard wasn't capable of running my Sennheiser 150ohm headset.
    Well it ran it with no bass at all as it didn't have the power to run them. Asus admitted the onboard wasn't up to the job so it is basically false advertising.
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    Apparently Sound Blaster ZXR is better
    but you need pay more cost for purchase
    actually onboard sound has already qualified for gaming
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Personally the onboard sound + the SupremeFX Hi-Fi USB DAC/AMP is more than enough for my needs.
    If you have the motherboard already, test it and see if you like audio as it is. If it doesn't meet your expectations, then go buy the sound card that you want.
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,462
    This is funny question... Sound Blaster ZxR + Pioneer SP PK52FS 5.1 Speaker System + Pioneer VSX1131 7.2 160W per channel receiver
    is best at the moment sound under 1000$. And could be compared with far more expensive systems.
    You can't imagine how sound games and movies with that and speakers quality.
    And only SB ZxR compare with SupremeFX is like most powerfull Mercedes with FIAT.
    Card cost 230-250$ more than most motherboards, how could be compared with onboard sound.
    Mar 2016
    12
    66
    ZxR without a doubt. Or SB ZX because ZxR is a little overkill. But most definitely a dedicated sound card.
