OC Panel
memetic
Like everything that breaks, one minute my OC Panel was working and then it just stopped working. The display is showing "0"s for all the values. So, it is on, it is just not getting the data.
I did not make any changes to anything before this happened.
Thank you!
ASUS Rig:
Motherboard model: ASUS ROG RAMPAGE V EXTREME/U3.1 LGA2011-V3 DDR4 M.2 ACWiFi USB 3.1 Type A Intel X99 eATX Motherboard
UEFI Version: 2001
CPU: Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W Desktop Processor BX80648I75820K
Memory kit part number (s) and amount in GB: G.SKILL Ripjaws 4 series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM 2133 (PC4-17000) Desktop Memory Model F4-2133C15Q-32GRR
GPU: ZOTAC GeForce GTX 980 Ti AMP! 6GB 384-Bit GDDR5 PCI Express 3.0 SLI Support Graphics Card (ZT-90503-10P)
SSD/HDDs/Optical drives: OCZ Storage Solutions RevoDrive 350 Series 480GB PCI Express Generation 2 x 8 Solid State Drive RVD350-FHPX28-480G
PSU: Thermaltake TOUGHPOWER GRAND 80 Plus Gold 1200W Semi Modular Power Supply TPG-1200MPCUS
USB Devices (model/version number): Transcend 1TB, Toshiba 1TB
Monitor: Asus
CPU Cooler: Corsair Hydro Series H110 280 mm High Performance Liquid CPU Cooler
PC CASE IYPC Alpha-DB6 Black Acrylic ATX Bench Case Bench Computer Case for ATX/Micro ATX motherboard
Operating system: Win7 Ultimate 64bit Activated
Drivers Installed (include version):
Any third Party temp/voltage software installed: No
System Overclocked (provide details)? No
5 REPLIES 5
memetic
Anyone? Any ideas? Should I flash the BIOS?
jrmcdou
The only time I had that issue is when the cable was a bit loose on the back of the panel. I had to cut off a bit of the rubber sheathing around the connector to make it fit snugly.
Rampage VI Extreme bios 1503
Core i9 7980XE @ 4.4ghz all cores
64 gb Corsair Vengeance RGB Pro 3600
2x RTX 2080 Ti FE NvLink/SLI
2x Samsung 970 Pro 1tb NVME
Corsair AX1600i
Corsair 1000D case
1x Dell U3818DW 38" Curved Ultrawide and 2x Dell S2716DG 27" 1ms GSYNC 2560x1440 144 hz
Win 10 Pro x64
you could try flashing the bios of the oc panel.
i accidentally mistook the oc panel for a front base and updated the firmware... luckily i was able to put the correct firmware back on 😉
https://www.asus.com/Motherboard-Accessories/OC_Panel/HelpDesk_Download/
might help
gene-iv-ocz-rev
I just got the new RVE 10TH and my OC panel was on and off depending on what I later found out was a bad wire. I ordered one of the long cables and what I guess is the power wire was loose. Once I fixed that it worked again.
QUOTE=memetic;599723]Like everything that breaks, one minute my OC Panel was working and then it just stopped working. The display is showing "0"s for all the values. So, it is on, it is just not getting the data.
Thank you!
ASUS Rig:
UEFI Version: 2001
Monitor: Asus
