07-14-2016 12:31 PM - last edited 3 weeks ago by ROGBot
07-14-2016 02:27 PM
07-15-2016 09:09 AM
The description for Event ID 267 from source Win32k cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
The start type of the Touch Keyboard and Handwriting Panel Service service was changed from demand start to auto start.
07-15-2016 09:30 AM
Open your Start menu, and type in Device Manager to search for it. Click on it in the results to open it. Click on the arrow next to Human Interface Devices to open up the drop down menu for it. Then find and right click HID-compliant touch screen. Click Disable. It will ask if you want to disable it because it may stop working - click Yes. Then right click again and click Enable, or Re-enable.
07-15-2016 11:01 AM
07-15-2016 01:26 PM
