Hello N0va. I remember having this problem too, but let's see if my gray matter retained what I did.
Definitely remove all other devices and just leave the Sammy
Did you clear the CMOS? You mentioned you have made settings adjustments, might as well at this point just start like new. Check the mobo manual how to clear the CMOS. Later once we get the Sammy to be seen you can go back and make whatever adjustments in the BIOS for those things.
Go in to the BIOS after clearing, go to "Boot" and make sure Fast Boot is disabled. Then scroll down and make sure CSM is also disabled. Save changes and reboot
Go back in to the BIOS and go back to the "Boot" tab, scroll down to Boot Option Priorities which is in gray. Below that and to the right it should say "Windows Boot Manager (samsung.....)
See if this helps. I remember that it was a pain to install, but clearing things and starting fresh makes the drive appear. I have even read to reflash your BIOS (1701) as another method, shut down completely, wait 30 seconds and then boot up again in to the BIOS and this sometimes works too
FYI, when the BIOS does finally find the Sammy and you begin the installation of Windows 10, do not use the Samsung NVMe driver. Just use the Microsoft NVMe standard driver as this forum that I hang out found a problem where in the S.M.A.R.T. readings the "Unsafe shutdowns" is increasing when there has never been a shutdown. My system had the Samsung driver and already it says I have had 12 unsafe shutdowns. Even on days when I had no shutdowns it records it as unsafe. I uninstalled the Samsung driver and just running off the standard Microsoft one and I am at 12 since. Others are in the hundreds.
Here is the site looking at this and were providing as much as we find out on this
http://www.win-raid.com/t2041f38-SAMSUNG-PRO-NVMe-SSD-unsafe-shutdowns-NVMe-driver-W-x-unexpected-sh...FYI and hopes this helps
[Asus ROG Maximus Hero VIII] [Samsung 950 Pro 512GB] [G.Skill 2 x 4GB = 8GB] [Asus PG278Q Monitor] [Asus Stryx 980Ti] [Windows 10 Pro, 64-bit]
