07-17-2016 10:11 PM - last edited on 03-06-2024 01:54 AM by ROGBot
07-22-2016 02:25 PM
07-26-2016 11:36 AM
FelixFFM wrote:
It blows air outwards, it's exhausted into the case, so good airflow is important. My card gets hotter when I have the case open, and stays cooler when it's closed.
Generally, exhaust fans are more effective with this scenario, as long as you have one or two intakes already.
07-26-2016 12:01 PM
07-27-2016 04:25 AM
Nate152 wrote:
Hi armadillo
You'd want the side fan as intake blowing air in, you shouldn't have much of a temp problem with all the fans you have. I'm like you I have 3 intake fans in the front, 2 intake fans at the bottom, 1 side panel fan and 1 exhaust fan at the rear. With this many fans it's probably best to use the motherboard fan headers although connecting your side panel fan to to one of the gpu fan headers might be more convenient.
Being that your fan is 3 pin you won't be able to control it by pwm, it will likely just run at full speed.
I set an aggressive fan curve on my Strix 1070 and max temp under full load is 61c.
08-16-2016 07:08 AM
08-16-2016 07:22 AM
08-16-2016 07:45 AM
