Results 1 to 3 of 3
    ROG Member Array xcite's Avatar
    Jul 2016
    16
    BIOS 2101 Question - Need help from 2101 useres...
    Greetings everybody!
    Because of constant restart and power looses I was froced to flashback BIOS from 3202 to 2101.
    And after this flashaback restarts and power looses seems to be gone - 3 days already of stable working.
    But now i have another problem:
    In 2102 BIOS under "Advanced" > "PCH Storage Configuration" option "Hot plug" for "SATA6G_7" - "SATA6G_10" had dissapeared !!!
    For "SATA6G_1" - "SATA6G_6" it is active.
    I've read the manual and it says that for "Hot plug" the "AHCI" must be enabled for correspopnding SATA Controller. It's enabled, but "Hot plug" is absent...
    Can someone take a look to your 2101 "Advanced" > "PCH Storage Configuration" ? Is "Hot plug" option available for "SATA6G_7" - "SATA6G_10" ?
    Thanks in advance guys!
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,533
    I'll take a look when I get home...if someone else doesn't get you the info first...
    EDIT: No, hotplug is not an option on those ports...
    Jul 2016
    16
    Quote Originally Posted by Arne Saknussemm View Post
    Yeap, just installed 3009, and "Hot plug" is available there for all SATA6G_x ports (1-6 & 7-10)...
    Seems to be that in 2101 and earlier this option does not exists...
