G751 fan led upgrade
Icemixxy
Hello.
I was thinking of sticking 2 led bands in front of the led grills, exactly like in the XOTIC PC Afterburner FX. Sadly, they don't do after sales modifications nor do they ssell the kit separately, thus I have to do it myself.
So I don't take the laptop apart twice, does anyone know the supply voltage to the rog led on the back of the screen? It says that they are hooking it up to that wire.
Thank you!
JustinThyme
Never measured it, probably wont find anyone that has. Only way to find out for sure is to open it up and take a measurement. Doesnt take much effort to get that far.
If I was forced to make an informed guess I would say 5 volts, anything more is a stupid design as that is plenty and already available on the board. Only other would be 12 volts but that's not likely or necessary. If you really don't want to take it apart twice then you can order up parts based for each and send back what you dont need when you are done of keep them for something else. Small Led light strips are dirt cheap.
Icemixxy
Might just do that. Thank you!
