Overclock 6950X with CX750M is possible??
Cneves
Hello guys!!
Since I began make my setup, I spent tons of money. Of course I want a great setup but the time to make money is important too.
So I decided to buy psu at the end (AX1500i). But now I´m using my old psu CX 750M and i would like to make an OC to 4,00Ghz.
My question is: Is it safe with this psu?? what do you think in your opinion??
At this time i´m using bios overclok with hypertreding but sometimes i have some delay in lightrrom
Thanks
Rampage V Extreme 3.1
Core i7 6950x
Corsair H115i
Strix 1080
32 Gb Trident Z 3000Mhz
Samsung 950 Pro
Intel 750 Pci
SSD (4) sata
HD (3) sata
HD (4) USB
Arne_Saknussemm
Level 40
That should be OKish....4.0 could draw 200W if you are stress testing but gaming etc will be a lot less...that PSU is a bit famous for being a "650W unit with a 750W lable"
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=416
If you have a 1500W incoming I'd probably wait...but if you just can't;) then go easy....don't hammer AVX testing
Wow!!! I didin´t know this :cool:
I will try and post the results here!
Thank you very much
Chino
Level 15
