Results 1 to 4 of 4
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Review: ASUS GTX950 Unplugged for low power PCs
    ASUS sent me its new GTX950 Unplugged for some testing and this is my experience. Feel free to ask questions!
    Look Ma! No wires!
    Overview
    This is an entry level graphics card for buyers who are budget conscious, constrained by a PC with limited upgradability, or have power/thermal concerns. What makes this card special is that it is designed to operate on only 75 watts of PCI-E slot power. It requires no external power connections which makes it ideal as a drop-in upgrade for virtually any PC, including those not intended for gaming. It's also extremely quiet. This card has a standard dual fan open air cooler but the power target is lower than most cards so it generates less heat and the fans do not have to work very hard. This means in addition to budget PCs this is also ideal for HTPC (Home Theater PC) usage where noise and small stuffy spaces are big problems.
    Obviously with only 75w of power to work with this card will not be a high performance GPU but how did it do? I don't have any similar GPUs for comparison or fancy charts so this will just be straight numbers.
    Specs for GTX950-2G
    2GB GDDR5
    Dual-slot
    DirectX 12 & OpenGL 4.5
    1x DisplayPort
    1x DVI Port
    1x HDMI Port
    SLI Bridge connector
    3 Year warranty
    MSRP $159.99USD
    (At time of writing Newegg has a lower price and a $20 rebate which makes it $130)
    Unboxing
    Box front:
    Box back:
    Box contents - No frills keeps the price low:
    Behold the card! The removable protectors on the gold fingers are a nice touch:
    The back - No backplate on this model:
    I/O - DisplayPort, DVI, HDMI:
    Test system
    Intel i7 2600k
    ASUS Maximus IV GENE-Z
    16GB DDR3 1600 Crucial Ballistix Sport
    Patriot Pyro SE SSD
    Tests Performed
    3DMark's Firestrike: Results are slightly lower than your average GTX950 due to the power constraint and also potentially due to the older test platform. After several runs the best score was 5553.
    Plants vs Zombies Garden Warfare 2 at 2560x1440 using automatic graphics settings maintained 40 FPS and up.
    The Witcher 3 at 1920x1080 on High settings with motion blur and Hair Works off consistently maintained 30+ FPS even in outdoor areas with fire spells.
    Ashes of the Singularity DirectX 12 benchmark saw an average of 29 FPS for all batches and a minimum of 21 FPS was reached.
    All of the above were using quality tuned settings so if you desire a higher frame rate, visual quality can be turned down for more performance.
    Power consumption and noise
    I don't have the ability to monitor individual components but I did verify total system draw with a power meter at the wall. Idle was right around 100w. Throughout testing *total system draw* was around 175w and peaked at just under 200w. This is in line with the rated 75w draw for this card.
    Even during heavy benchmarking the GPU noise never got above the volume of the 120mm CPU cooler. This is with a completely stock fan profile. No need to adjust it. I'm impressed.
    SUMMARY
    For the price point this card performs very well. It also meets a unique need for those with limited systems or HTPC builds. In the right situations this is the ideal card. It sips power and runs quiet. However, the ASUS GTX950 STRIX is only $10 more and has better performance. Also the ASUS GTX960 STRIX has a rebate on Newegg which makes it $155. The two STRIX cards do require a 6-pin power connector but that can also be adapted from two 4-pin molex connectors if a power supply doesn't have a PCI-E power connector. That extra power even allows the STRIX cards to be overclocked a bit if the power supply is reasonably sized. So most buyers would get more value out of a STRIX if they can handle the extra heat and power requirement. But if 6-pin power is not possible or noise is critical then this Unplugged 950 will do the job quite well.
    Overall I give this card a 8/10
    Very well designed for a specific need but most buyers should also consider similarly priced ASUS products that offer a better price/performance ratio.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Hi all,
    I don't generally do reviews and I'm just your average gamer with pretty average tools. So I'm open to feedback on this. If there's anything that needs to be spruced up just let me know and I'll do my best.
    I apologize for the grainy photos but I just have a regular point & shoot from a few years back. I have higher resolution versions upon request but I don't feel they captured much more detail than these resized images.
    I'm willing to do more testing if anyone feels it would help but in general these results are pretty representative of the performance you can expect on current titles. This is a budget card so buyers should not expect miracles but by adjusting settings the vast majority of games will be playable.
    Also, I upgraded my original score because I missed that this would be well suited in a HTPC. Given the lack of good options in that market sector it's definitely a point in this card's favor.
    -xero
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,689
    That's pretty decent performance for a GPU with no extra power requirements! If you had a GSync monitor you could game quite happily just turning down a setting or two
    So when are you starting up Xereviews.com?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Quote Originally Posted by Arne Saknussemm View Post
    That's a good point on GSync. I don't have one to test but you're right. Since this card is a good fit for HTPC it would be nice to test it with a 50" adaptive sync TV.
    I respect those guys trying to make a living doing news & reviews. It's a tough gig so I don't think I'd ever attempt it but it's fun doing this as an amateur while I keep my cushy day job!
