Results 1 to 3 of 3
Thread: PCI-E issues
    Nakano2k1
    Guest
    PCI-E issues
    I recently purchased this board and everything was running fine until I updated the bios. Now my GPU in the top PCI-E X16 slot runs at 8x instead of 16X. The bottom GPU is running at 16x however.
    I needed to update the bios to support my new CPU (Phenom II X4 970).
    Is Asus going to do anything to address this issue?
    ROG Guru: Blue Belt Array martin_metal_88's Avatar
    Apr 2010
    777
    Well if the issue is found to be happening for many people I'm pretty sure they will fix it, Brian could answer you with that. But it it's only a issue that affect you then it would be harder. Maybe you could try to flash again and reset the bios? only to see.
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
    Bonedoctor
    Guest
    This happened to mine as well. I went back to an older bios and it didnt fix it, instead it ramped my CPU upto 1.79 volts from the rated 1.375 . Since then ,the #1 slot has completely stopped working. When I coldboot the PC ,the card in that slot runs the fan at 100% and it wont post. I cant even get the LCD to Det Dram. RMA in processs atm !
    Amazing product other than this =)....Wouldnt want another board till They come out with 4 CPU's on 1 board !
Similar Threads
  1. G73JH-A1 Touchpad Issues! H-E-L-P
    By renvet in forum G Series Gaming Notebooks
    Last Post: 03-18-2011, 02:44 PM
  2. Intel RST driver issues
    By Nakano2k1 in forum G Series Gaming Notebooks
    Last Post: 12-29-2010, 10:28 PM
  3. G73 Keyboard issues
    By Mif in forum G Series Gaming Notebooks
    Last Post: 12-07-2010, 10:24 AM
  4. G73 Video Issues
    By Dracowyr in forum G Series Gaming Notebooks
    Last Post: 09-20-2010, 06:44 AM
