Results 1 to 7 of 7
    ROG Member Array Shammer PC Specs
    Shammer PC Specs
    MotherboardAsus Rampage V Extreme/U3.1
    ProcessorIntel I7-5930K
    Memory (part number)G.SKILL Ripjaws 4 Series 32GB F4-2666C15Q-32GRR
    Graphics Card #1EVGA GeForce GTX 980 Ti 06G-P4-4996-KR 6GB FT
    Graphics Card #2EVGA GeForce GTX 980 Ti 06G-P4-4996-KR 6GB FT
    MonitorASUS ROG SWIFT PG279Q 27"
    Storage #1OS: Samsung 950 PRO 512GB PCIe 3.0 M.2
    Storage #2Samsung 850 EVO-Series 1TB
    CPU CoolerNZXT Kraken X61
    CaseCorsair 780T
    Power SupplyCorsair 1200i
    Keyboard Razer Black Widow Untimate 2013
    Mouse Logitech G602
    OS Win10 Pro
    Apr 2016
    6
    Memory Problems - Suggestions?
    Hi, Folks -
    I've been using this rig for about 2 months, and I'm starting to get memory-related BSOD's. I'm currently running BIOS 3202, and I'm not an overclocker. I'm looking for a good place to start.
    I had the XMP enabled, so I deleted that and went back to Auto settings in the BIOS, but I'm looking for a baseline to start troubleshooting.
    What's the preferred memory testing with you folks? I got the AIDA64 Extreme package - is that what you use, or is Memtest86 a better option?
    Should I stay at BIOS 3202 or go to the latest release?
    Go back to the BIOS XMP settings or stay on Manual?
    My objective is to just get a stable memory configuration, although I may learn more about overclocking both CPU and memory once I get things settled down.
    Although I'm not an overclocker, I'm experienced with PCs and I've been a PC systems admin for over 20 years at work.
    If you need more info than what's in my Forum profile, please ask and I'll provide it.
    Thanks in advance for any advice!
    Tim
    ROG Guru: Brown Belt Array MeanMachine PC Specs
    Laptop (Model)I enjoy my wife
    MotherboardCVI HERO + CVII Hero Wifi
    ProcessorRyzen 7 1800X + 2700X
    Memory (part number)CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR
    Graphics Card #1EVGA GTX980 SC for CVFZ
    Graphics Card #2EVGA GTX 1080 hybrid
    Graphics Card #3GTX 770 for phys x
    Sound CardMB
    MonitorHP w2408h
    Storage #1Samsung 970 EVO 500GB M.2
    Storage #2Samsung 840EVO 500GB and 960 M.2 pro
    CPU CoolerCorsair H105, H110 and H115i
    CaseCorsair 750D and 780T
    Power SupplyCorsair AX-1200i and Antec 850 pro platinum
    Keyboard Logitech K800
    Mouse Razer Mamba
    Headset Corsair Vengeance 2100
    OS W7 Ultimate 64bit and W10 pro 64bit
    Network RouterNetcom Wireless NF18ACV
    MeanMachine's Avatar
    Apr 2014
    126
    1,687
    Well your DIMMs are listed and tested according to the QVL for your MB. so they conform.
    MemTest86+ is the best test run from USB. Both AIDA64 and MemTest86+ are good compared to windows.
    Bios 3301 is latest Bios for better stability.
    Use your XMP profile and manually key in Primary timings and voltage.
    You can't OC a none "K" version Intel CPU.
    Put HWMonitor and AIDA64 side by side on you desktop.
    run the CPU and FPU test first for 10mins then take a screen shot and post the result.
    Lets see if any changes in Bios will help.
    We owe our existence to the scum of the earth, Cyanobacteria
    My System Specs:
    MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
    CPU:
    AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
    Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,687
    HCI memtest or the Google Stressapp test are supposed to be good for this platform.
    BIOS wise....did you have the same problems on previous BIOS..like 2101 or earlier? Latest is not alwaya greatest...but if you have problems then by all means flash latest BIOS flashback method....you can always roll back..
    When you set xmp....does that set 125 strap?...if so maybe try setting up manually on 100 bclk
    By the way I am assuming you have a single quad kit right?
    Test individual sticks to see if they are all working ok.
    Shammer PC Specs
    CaseCorsair 780T
    Mouse Logitech G602
    OS Win10 Pro
    Apr 2016
    6
    Thanks for your suggestions, Mean & Arne.
    I've loaded 3301 and taken all the defaults except these:
    PCIE8_4 and M.2 Configuration from Auto to M.2 (since I have the M.2 slot as my primary OS/boot drive)
    Post Delay from 3 seconds to 0
    Arne, I looked at the XMP settings while I was in there and verified that there is only one XMP profile:
    XMP DDR4-2667 15-15-15-35 1.2V
    The strap default is 100, with the following available: 125-167-250
    After saving and booting to Windows, I ran a quick AIDA64 stress test on just the memory and got the BSOD within 2 - 3 minutes.
    So, next I'm going to do the tedious job of testing my RAM modules one by one. I'll check in when I finish.
    One question: how do you folks make screenshots of the BIOS? I've been using Snagit for years, but that only works in Windows.
    Thanks again, back soon...
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    Hello
    With 32GB of memory GSAT is a better option than HCI for memory only testing. It is much faster.
    Apr 2012
    505
    13,687
    If you are having no joy setting XMP maybe try bumping dram voltage a touch...like 1.25 or 1.3v
  7. #7
    ROG Guru: Orange Belt Array Legolas PC Specs
    Legolas PC Specs
    MotherboardMaximus X Hero Wifi AC
    ProcessorIntel Core i7 8600k oc 5Ghz
    Memory (part number)Samsung DDR4 16GB
    Graphics Card #1ASUS NVIDIA GTX 1080
    MonitorASUS MS246
    Storage #1Samsung MZVPV256
    Storage #2Samsung MZVPV256
    CPU CoolerCorsair H110I v2
    Power SupplyPC 1200W Turbo-Cool 1200
    Keyboard ASUS SK2045
    Nov 2015
    277
    What is your timing? It should be set to 15-15-15-35-2N? If you OC, you have to slow the timing and increase frequencyy like 16-16-16-36-2N with 2700(for example)
