Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    ROG Guru: White Belt Array Costas PC Specs
    Costas PC Specs
    MotherboardMaximus Formula VIII
    ProcessorI7-6700K
    Memory (part number)Corsair CMD16GX4M2B3200C16
    Graphics Card #1EVGA 980Ti Classified
    Graphics Card #2EVGA 980Ti Classified
    MonitorROG PG278Q
    Storage #1Samsung 512GB 950 PRO M2
    Storage #2Samsung 1Tb 850 PRO + WD Black HD's
    CPU CoolerCustom Loop
    CaseCaselabs SMA8
    Power SupplyCorsair Ax1500i
    Keyboard Corsair K70RGB
    Mouse Razer Deathadder 2013
    Headset Razer Tiamat 7.1
    Costas's Avatar
    Jul 2014
    25
    118
    Quote Originally Posted by pamarakos View Post
    But doesn't fix the hibernate - shutdown leds issue plus if you simply turn off the leds in AURA app and exit the app and re-open it you must find again the colour
    you last used, it doesn't remember the last one used...
    Ah OK - I think I tried suspend and that worked OK but did not try 'hibernate' as such.
  2. #12
    ROG Enthusiast Array
    Jul 2016
    35
    Quote Originally Posted by Costas View Post
    EPIC but last time I hibernated without touching anything anywhere, m/b leds turned off and I was able to wake up my pc from keyb and they were back on.
    Now that I re-tried to hibernate they stayed on as usual....so it can be done for sure, come on guys do it somehow....it can be done by motherboard's mistake and can't be done normally??
    P.S. Another new was that I switched off leds through Aura app and as soon as I hibernated these switched on by themselves and kept on till I
    re-switched on the pc
    All these are happening with the last version of the Lightning Control app downloaded from the website (not with the version included in the
    CD of the package). With this version it remembers the colors last used but it does these..."things"
Tags for this Thread
