System does not allow to flash bios
dpkmon
Hi everyone.
I'm trying to update my bios, however when I enter the easy flash utility, the title message shows.
Does anyone know why?a
Also having the same problem using the WinFlash utility, it just loads and does nothing.
Thanks everyone!
9 REPLIES 9
dpkmon
Thanks everyone, now fixed.
You need to put the battery of the notebook and restart it (weird)
Updated flawlessly with Winflash.
I haz numlock
BrodyBoy
In the future, play it safe and don't use WinFlash. I know that it works sometimes, but it's well-known to have a higher failure rate than Easy Flash. I just don't think it's worth taking the risk.
Just curious, what do you mean by "you need to put the battery of the notebook and restart it?"
dpkmon
If I have the notebook plugged to the Ac adapter, I take the battery off (I believe this extends the battery's life)
WinFlash kept saying to have at least 20% battery, since I was using the ac, I thought it didn't matter.
Silly me, placed the battery, restarted and it worked.
shol
Just because winflash would not realize that your battery wasn't there is another good reason to not use it lol 🙂
fostert
Level 12
Agreed, avoid updating BIOS from any OS platform! You're just asking for it (an RMA, that is).
G74SX-CST1-CBIL, i7 2630QM 2GHz
32GB DDR3 RAM @1333MHz
GTX560M 3GB DDR5 (192 bit)
17.3" LED 1920x1080
Sentelic TP, BIOS 203
Debian Linux Wheezy (Testing) Kernel 3.2, NVIDIA 295.40
I'm have an Asus A75VJ-TH71, purchased 2-3 months ago and I have a problem.
I update latest bios (BIOS 230). http://support.asus.com/download.aspx?SLanguage=en&p=3&s=402&m=A75VJ&os=&hashedid=2MVjBTSQPxFPF8Cb
but update later my notebook restart, my laptop shows a blue screen no boot i don`t know
http://support.asus.com/Documents/detail.aspx?SLanguage=en&p=3&m=A75VJ&s=402&hashedid=2MVjBTSQPxFPF8... Someone help me pls :((
Pitcher1
i think you use winflash to update BIOS right, i thin you can download old version BIOS and save to usb derivce that is can be booting, press ctrl + home to flahs back old bios, if ok, please update bios by ezflash at bios. if not, i think you will sent to service center.
Naraa
cl-Albert
US Customer Loyalty Agent
Moved your thread to the non-ROG notebooks.
If you have not already, you may want to try to reload your default bios settings and confirm your SATA mode selection is correct for AHCI, IDE, etc.
Otherwise, you may want to check this contact page for the nearest ASUS support office.
