Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,345
    Xsplit Gamecaster Guide
    Hi everyone !
    If you've recently purchased a Strix GTX 1060/1070/1080, Asus gives you a nice bonus with a full free year of Xsplit Gamecaster, so what is Xsplit Gamecaster? It's a neat little tool to stream and record your videos to show off your amazing gameplay to us and your friends. You can install Xsplit Gamecaster from the Strix dvd or you can install it from the Xsplit website.
    Click download under Xsplit Gamecaster and create an account.
    https://www.xsplit.com/
    To get your free year of Xsplit Gamecaster you'll need the PPID number and serial number, if you didn't install your gpu yet great, if you did you'll have to remove it from the motherboard to get the PPID number. The PPID number is the first set of numbers on a little white sticker just above the pcie x16 connector, the serial number is on the Strix box.
    Once you get the PPID number and serial number go here below, at the bottom of the page in blue follow the steps for the "1-Year Premium License Redemption", you will be presented with a license key and an email will also be sent to you with the key.
    Click Redeem Now !
    http://www.asus.com/event/2015/VGA/XSPLIT/index.aspx
    Now that you've got the key, open up Xsplit Gamecaster and click the little arrow to the right of your email/log in name and click "Redeem gift certificate".
Name:	Xsplit Gift Certificate.png
    You will be presented with the gift certificate redemption page, enter your key and click continue.
Name:	Xsplit key redemption.png
    You should then see your Premium License good for 1 year + 2 weeks. ( Xsplit gives you two weeks of premium service when you install Gamecaster )
Name:	Premium License.png
    Live Streaming - You can choose between sites you want to stream to and I chose YouTube since I already have an account, if you don't have a YouTube account it's easy to create one through Google then go to YouTube and sign in.
    https://accounts.google.com/SignUp?hl=en
    With Xsplit Gamecaster open click the settings tab, under GAME CAPTURE you see stream settings. Click the gear to the far right of stream settings, here you can select what settings you want it to stream.
Name:	Xsplit Stream Settings.png
    For the best quality set:
    RESOLUTION - 1440p Quad HD
    CODEC - x264 (uses cpu)
    FRAMERATE - 60
    BITRATE - Automatic, Constant
    Then click close.
Name:	Gamecaster Settings.png
    Now click on the Accounts tab, under "Live Streaming" click the little arrow to the far right and a list of sites come up you can stream to, select YouTube Live. It may ask you to verify your account, all you'll have to do is enter your phone number, an automated person will call you immediately with a 6-digit number, enter it and continue.
Name:	YouTube Authorization.png
    With Xsplit Gamecaster open start a game, once your game loads hit CTRL+TAB to bring up the overlay and click Stream.
Name:	Xslpit Overlay.jpg
    Then click START BROADCAST, you are now Live Streaming to YouTube.
    Once you're done streaming go to your YouTube account, it will automatically save and process what you've streamed, click on video manager and it will show this. Wait until it's done processing then click publish , the higher the resolution and the longer your gameplay the longer it will take to process.
Name:	YouTube processing.png
    Here's the gameplay video that was streamed.
    Recording - Click on the settings tab, beside RECORD SETTINGS click the gear to the far right.
Name:	Record Settings.png
    FRAMERATE - 60
    Quality - Ultra High
    Then click close.
Name:	Custom Record Settings.png
    With Xsplit Gamecaster open start a game, once it's loaded hit CTRL+TAB to bring up the overlay and click Record, gameplay is recorded to your ssd/hdd.
Name:	Xsplit Overlay Record.jpg
    once you recorded what you want close the game and Xsplit will ask you if you wish to stop recording now, click yes and go to the Recordings tab. Right click on your video and click "Optimize For Web".
Name:	Optimize for web.png
    When it's finished it will say "moov fix succeeded".
Name:	moov fix succeeded.png
    To upload your gameplay video go to YouTube, on the upper right corner click Upload.
Name:	YouTube Upload.png
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    Click the big arrow in the center of the page then on the left click This PC, Local Disc ( C: ), Users, your name, videos, Xsplit videos, your video, it will be put by file name then click open. I suggest doing it this way because sometimes drag and drop doesn't work.
    Attachment 58674
    Your video is now uploading to YouTube, when it's finished processing click publish.
Name:	Upload Recoded Gameplay.png
    Here is the recorded video.
    Xsplit has its own little on screen display to see frames per second, cpu load and running time. With GPU Tweak installed you can see gpu clock speed, Vram usage and gpu temperature, you can see these while streaming or recording but doesn't show on playback.
    To enable the on screen display click the settings tab and scroll down to the Status Bar, put a checkmark beside all of them. To the right you can choose where you want the on screen display displayed I have it set to the upper left corner of the screen.
    To take a screenshot you'll have to set a hotkey, you can use any key you want except for your normal gameplay keys. Click settings and scroll down to Hotkeys, click the box to the right of "Screenshot (Capture)", highlight it and hit what key you want for a screenshot, I chose the home key.
    When you're in game hit the hotkey you chose, it will tell you a screenshot was saved in your Xsplit screenshot folder located in your pictures.
Name:	doom screenshot.jpg
    Notes:
    1) To stream in high resolution an i7 cpu is preferred but an i5 should suffice.
    2) To get 1440p playback install google chrome and use it.
    3) Run time is only shown with streaming.
    4) Once you've uploaded your recorded video to YouTube you can delete it from your ssd/hdd to free up space, you can view it on YouTube and upload it from there to here.
    We would like to see your recorded gameplay videos so post all the videos you want, if you have any questions please ask.
    Ex-employee Array
    Jun 2020
    108
    2,154
    Nate, thank you for this extremely detailed guide. I used xsplit once before but I learned a lot more after reading through this guide.
    ROG Guru: Orange Belt Array AKBAAR PC Specs
    AKBAAR PC Specs
    MotherboardASUS Maximus Impact VIII
    ProcessorIntel i7-6700k @ 4.6Ghz
    Memory (part number)TridentZ 3200C14 - 32GTZ 32GB
    Graphics Card #1MSI GTX 1080 Gaming X
    MonitorDELL U3014
    Storage #1Samsung 840 Pro SSd
    Storage #2Samsung 840 Pro SSd
    CPU CoolerCorsair H80i GT
    CaseCorsair 250D
    Power SupplyCorsair AX760i
    Keyboard Corsair k70-rgb
    Mouse SteelSeries Rival 100
    OS Windows 10 Pro X64
    Network RouterASUS RT-AC5300
    Dec 2013
    251
    omg Nate, Thank you so much man ! REP+++++++++++++
    So i got the MSI GTX 1080 and got free 1 year subscription for gamecaster and I immediately found you Nate! this gonna be FUUUUUUUUUUUUUUUUUUN
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    Cool thanks for the rep, please post some videos when you get some made.
    The guide is for Strix gpu's so getting the free year through MSI may be a little different.
    AKBAAR PC Specs
    MonitorDELL U3014
    CaseCorsair 250D
    Dec 2013
    251
    Quote Originally Posted by Nate152 View Post
    Nate, So i am trying to Stream on Twitch but am getting so many Drops in the stream and so much buffering.
    do you have any advice for me how to do settings properly?
    https://www.twitch.tv/akbaar
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    What is your internet speed?
    I have 90mb/s
    I tried Twitch, I was streaming fine there too. You can only stream, you can't upload recorded vidoes to Twitch.
  8. #8
    AKBAAR PC Specs
    MonitorDELL U3014
    CaseCorsair 250D
    Dec 2013
    251
    I have 90mb/s
    10mb/s upload
    i just need optimal settings, and would luv to stream 1440p or more
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    What is your download speed?
  10. #10
    AKBAAR PC Specs
    MonitorDELL U3014
    CaseCorsair 250D
    Dec 2013
    251
    oh lol its 50mb/s
    https://www.twitch.tv/akbaar/v/83599653
    look at this, I put 1440p but it reverts back to 540p !
    so much downgrade i dont know why
