Results 1 to 10 of 47
08-08-2016 06:16 PM #1
SimondsUnchaind PC Specs Motherboard Rampage V Edition 10 Processor Intel I7 6850k Graphics Card #1 ROG Strix 1070 Sound Card Schiit Jotunheim Monitor Dell S2417dg Storage #1 512MB Samsung 950 pro Storage #2 3TB WD Black CPU Cooler Thermaltake 3.0 UIltimate Case Thermaltake V51 Power Supply 1000W EVGA PS Keyboard Corsair K70 RGB Rapidfire Mouse Corsair M65 Pro RGB Headset Focal Elear Mouse Pad Corsair Extended Headset/Speakers Emotiva S5 powered monitors OS Windows 10 Home 64bit
- Join Date
- Jul 2016
- Reputation
- 10
- Posts
- 45
RVE10 with G.Skill Trident Z DDR4 incompatibility
Hey guys!
I just finished building my first PC and upon the first boot, I get error 53 (memory failed to initialize...), I cannot get past post and into the BIOS
The Ram I'm using is the G.Skill Trident Z DDR4 3200 32gb kit (4 x 8gb)
Series Trident Z
Memory Type DDR4
Capacity 32GB (8GBx4)
Multi-Channel Kit Quad Channel Kit
Tested Speed 3200MHz
Tested Latency 16-18-18-38-2N
Tested Voltage 1.35v
Registered/Unbuffered Unbuffered
Error Checking Non-ECC
SPD Speed 2133MHz
SPD Voltage 1.20v
Fan lncluded No
Height 44 mm / 1.73 inch
Warranty Limited Lifetime
Features Intel XMP 2.0 (Extreme Memory Profile) Ready
This memory is not listed on Asus's QVL for the motherboard but on G.Skills website, the Asus Rampage V edition 10 motherboard is listed on this memory kits QVl. Not sure why they would be conflicting.
I'm using an:
Asus Rampage V Edition 10
Intel I7 6850k
Asus Strix 1070
950 pro 512gb SSD
3TB WD Black
Evga 1000w PS
Any help would be much appreciated!
Here's a link to a video if anyone cares : https://www.youtube.com/watch?v=R_qh...ature=youtu.be
08-08-2016 07:19 PM #2
FireRx PC Specs Motherboard Rampage VI Extreme Processor Intel 10900 X Memory (part number) Corsair CMD32GX4MA2800c16 Graphics Card #1 Nvidia RTX 3090 FE Sound Card onboard Monitor LG 34" curved Storage #1 Samsung 960 M2 SSD 1 terabyte Storage #2 Samsumg 860 EVO SSD 2Tb CPU Cooler Corsair H80i Case Lian Li VS2000 Power Supply Thermaltake 1200 modular Keyboard Logitech K800 Mouse Logitech Headset Powerbeats Pro Mouse Pad Xtrac Ripper XL Headset/Speakers logitech OS Windows 10 Pro 21277 Network Router NetGear Accessory #1 Logitech G940 FLight gear
- Join Date
- Apr 2013
- Reputation
- 33
- Posts
- 712
yeah I did this on my X-79 build and paid for it dearly not following ASUS's QVL . Even though they did work. I would get occasional errors in Windows. See if you can return them in trade for a memory kit that is on the QVL. You'll be much happier in the end.
I can almost bet you money that mobo is trying to initialize that memory on 1.2v.
Intel Core i9 10900X @4.7ghz @1.182v
Asus Rampage VI Extreme [bios 3105]
LG (34U97-s) Monitor 3440 x1440
Nvidia RTX 30909 FE
Windows 10 Pro
32gbz Memory
08-08-2016 08:18 PM #3
- Join Date
- Jul 2016
- Reputation
- 10
- Posts
- 45
I spoke with G.Skill just now and the guy on the phone first, hung up on me when trying to explain my situation, So I called back, got the same guy, called him out (lol) and he then listened. He said they tested the Asus RVE10 board with my specific memory kit, to which it worked for them. I have not yet flashed my BIOS up to the newest version (0901), so he recommended that I do that first and try the ram again. I generally just want the Ram to work so I don't have to deal with shipping the memory for a return and I'd be lying if i said I didnt choose the ram because the sexy black and white look.
Once I flash my BIOS (once I've learned how lol), I will report back my findings.
08-08-2016 10:00 PM #4
- Join Date
- Apr 2013
- Reputation
- 33
- Posts
- 712
yeah it's pretty easy to flash the bios, I just did a few hours ago. just make sure the UBB you use is formatted fat 32.
Nvidia RTX 30909 FE
Windows 10 Pro
32gbz Memory
08-08-2016 10:27 PM #5
Although I don't have this kit is is hard to imagine this memory not working with the R5E10. The 3200 CAS14 and 3600 CAS 15 kits I have work without issue.
08-08-2016 11:00 PM #6
- Join Date
- Jul 2016
- Reputation
- 10
- Posts
- 45
After updating the BIOS to the current version (0901), I am still having no luck and cannot get past the post with error 53.
I have tried each memory module in the D1 DIMM slot per Asus's recommendation over the phone. I asked as to why this kit would be incompatible for any other clues but was told "because its not on the QVL"... so not sure where to go from here.
When It stops on error 53. An orange LED illuminates the left of the tiny white switches, Specifically the switch #4. Also, an LED lights up near the ATX power supply labeled RAM_CD (probably because RAM is in the D1 slot)
DRAM light
PCI-E lane lights - this part troubles me because I have nothing plugged into the 4th PCI-E slotLast edited by SimondsUnchaind; 08-08-2016 at 11:44 PM.
08-09-2016 12:21 AM #7
santz76 PC Specs Motherboard Rampage V Edition 10 Processor I7- 6850k 4.4ghz Memory (part number) GSkill Trident Z 64gb DDR4 3400hz Graphics Card #1 Asus Rog Strix GTX 1080 Graphics Card #2 Asus Rog Strix GTX 1080 Sound Card Sound Blaster Z Monitor Rog Swift PQ348Q curved monitor Storage #1 Corsair GTX Force 500 GB SSD Storage #2 Corsair force gt 500gb CPU Cooler Swiftech h240x custom apogee xl rog water block mayhems blood red coolant Case Corsair 760T Power Supply Corsair AX 1200I Keyboard Corsair k70 (cherry reds) RGB Mouse ROG GLADIUS Headset Astro A40 PC TR Editions Mouse Pad Asus ROG Sheath XL mouse pad OS Windows 10 / Samsung 950 pro M.2 Network Router Asus RT-AC87U Accessory #1 Saitek X52 Pro Accessory #2 DX Formula red/black gaming chair
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
when using quad channel sticks make sure they are slotted in the GRAY slots only, dimm slot A1-B1-D1-C1. these kits will definetlly work as i have 64gb, fyi i believe they are 1.35v ram
08-09-2016 12:37 AM #8
- Join Date
- Jul 2016
- Reputation
- 10
- Posts
- 45
Could you tell me your Memory Kits product code? Just got off the phone with Asus support and he said that the Trident Z RAM lineup is for only the Z170 chip set; I know that's not true..
Also, the blinking PCI-E lane 4 light pictured above is either because my PCI-E lane is broken (out of box) or the board is having a grounding issue.
Currently tearing everything out of the case to build on a box to test for grounding problems.Last edited by SimondsUnchaind; 08-09-2016 at 01:17 AM.
08-09-2016 12:39 AM #9
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
f4-3200c16q2-64gtzsk, these are for x99 chipset, also i had the z107 trident z 3400 on here before these with no issues
08-09-2016 12:41 AM #10
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
follow this maybe u need to manually set your voltage in bios to get the 3200 i had to with mine but this should help!https://www.youtube.com/watch?v=dW6gBneg3VA
