Load indicator not working (LED's on GPU)
BCI1999
Hi, for quite some time the led lights on my gpu, wich are supposed to indicate the load level stays on yellow (medium load), it will never go to red even if the load is 100%.
I'm talking about the Matrix 980ti.
Here's a link to those led light I mean http://www.asus.com/us/Graphics-Cards/MATRIX-GTX980TI-P-6GD5-GAMING/#rogm-section-color
Thanks in advance.
4 REPLIES 4
Nate152
Hi BCI1999
Welcome to the ROG forum.
I have the ROG matrix platinum 980 Ti and it turns red when under full load.
Are you sure it's under 100% load?
Nate152 wrote:
Hi BCI1999
Thanks for the quick reply 🙂
I'm 100% sure it is at full load (99%) https://gyazo.com/127698e369036e2dbc68451063fb5393
But now it doesn't even turn yellow anymore, it just stays blue (almost no load)
Nate152
You're welcome
If you're running a game or benchmark, try setting the antialising to 8x to see if that turns it red.
Make sure V-Sync is disabled too.
Nate152 wrote:
You're welcome
Did everything, still the same. Sometimes it will turn yellow, but never to red.
