Results 1 to 3 of 3
    ROG Member Array ftjacques PC Specs
    ftjacques PC Specs
    MotherboardASUS RAMPAGE V EXTREME
    ProcessorIntel Core i7 5930K @ 3.5 GHz
    Memory (part number)CORSAIR VENGEANCE LPX 2666 MHz 8x4GB CMK16GX4M4A2666C15 (x2)
    Graphics Card #1ASUS GEFORCE GTX980 4GB
    Graphics Card #2ASUS GEFORCE GTX980 4GB
    Sound CardOnBoard ROG SupremeFX 8-Channel High Definition Audio CODEC
    MonitorASUS PB287Q 4K IPS 28 inch
    Storage #1SAMSUNG MZHPU512HCGL-0004 (512 GB M.2 PCIx SSD)
    Storage #2KINGSTON SH103S3240G
    CPU CoolerCOOLERMASTER HYPER 212 EVO
    CaseTHERMALTAKE CORE V71
    Power SupplyCORSAIR AX1200
    Keyboard RAZOR BlackWidow
    Mouse LOGITECH G700s
    Headset RAZOR Megalodon
    Mouse Pad None. Absolutely none.
    Headset/Speakers LOGITECH 5.1 DTS THX Very Old But Amazing set of unremembered model
    OS Windows 10 x64 Enterprise N
    Network RouterMy main pc (Windows ICS, with a 2nd netcard)
    Jul 2016
    15
    Lightbulb A way to start VLC and not stop at mouse movement
    Hi everyone,
    just a small quality of life suggestion I have regarding RealBench-
    It would be very nice if it was possible to launch the Heavy Multimedia test and not have it stop due to mouse movement. Obviously, this wouldn't have to yield any testing result in itself, but just a way to let us adjust the volume of the test.
    I personally tend to have my speakers way up high in volume, and reduce all my applications in Windows to ~15% volume so they don't wake up the neighbours. The point of this is to be able to cramp up the volume on those few videos that can't be heard at all unless you really pump it up.
    With the way RealBench is setup actually, this is almost impossible, I had to launch the test around 5 to 10 times in a row and try to reach the volume mixer in time before VLC disappears from it to achieve that.
    Obviously, this isn't a deal breaking thing, just a small QoL improvement that wouldn't be hard to implement imho.
    Best Regards,
    Thierry
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    Hello
    The stress test does not stop with mouse movement. Only the benchmark part of RealBench monitors mouse movement.
    ftjacques PC Specs
    Jul 2016
    15
    Quote Originally Posted by Praz View Post
    Hello
    Seemed like a good point until I tried it... The stress test only seem to use Handbrake, and not VLC, so it doesn't allow me to fix the volume sadly. Unless I'm doing something wrong?
Tags for this Thread
