1070 Strix OC Fan Connectors
Snyder99
Hello all,
This may have been answered elsewhere, but I am having trouble finding a way to connect my card's 4-pin fan connectors to my motherboard. Both are male 4-pin connections, and in my searching, I have been unable to find 4-pin female to female connectors. Anyone know of where I can find them?
Thanks!
Praz
Hello
The fan headers on the 1070 are for connecting fans to not connecting to the motherboard.
Keidj
Snyder99 wrote:
Hello all,
Thanks!
You connect your 4-pin PWM fans directly to your graphics card. In my case I have 2x 140mm fans for intake wich I connected to the 1080 fan headers. Now you can control those fans connected to the graphics card using GPU Tweak. GL! 😃
Awesome, thanks for the help! That makes a ton more sense!
