Wake On Lan problem
Kriminal73
Hi to all,
I'm trying to enable the WOL function without any success.
On bios I've disabled the fast boot, enabled the Power On By PCI-E/PCI and enabled the magic packet on Windows 10 Ethernet properties, but still cannot turn on the computer with WOL.
Any suggestion?
Kriminal
Μobo:ASUS RAMPAGE V EXTREME bios 3301-CPU:INTEL I7 5960X-Cooler:Noctua NHD15-RAM:HyperX Predator CL15 4x4GB6-GPU:ASUS STRIX GTX 1080 OC-PSU ANTEC 1200W dual power supply-SSD Crucial M550 512 GB (boot with Win 10 Pro)-HDD 4x2TB Seagate Raid 10+2x1TB Raid 0- Case Antec P190
sergio77
Kriminal73 wrote:
Hi to all,
Any suggestion?
Kriminal
Μobo:ASUS RAMPAGE V EXTREME bios 3301-CPU:INTEL I7 5960X-Cooler:Noctua NHD15-RAM:HyperX Predator CL15 4x4GB6-GPU:ASUS STRIX GTX 1080 OC-PSU ANTEC 1200W dual power supply-SSD Crucial M550 512 GB (boot with Win 10)-HDD 4x2TB Seagate Raid 10+2x1TB Raid 0- Case Antec P190
Try these steps in this order:
1. Install newest LAN driver;
2. Disable or Enable the ERP (S4-S5) in UEFI;
3. Turn Off Fast Startup in Windows 10 (power options).
4. NIC driver settings: Enable "Allow the computer to turn off this device to save power", Enable "Allow this device to wake the computer", Diable "Allow the computer to turn off this device to save power"
After each single step please reboot OS, and try WOL function.
Intel Core i7-5930K @ 4.5GHz / Cooler Master Nepton 280L / Noctua NF-A14
Asus RAMPAGE V Extreme / Kingston HyperX 32GB DDR4 3000MHz
Asus Strix GeForce GTX 980 / Asus VX279Q
Samsung 950 Pro NVMe 512GB / Samsung 850 Pro RAID 0 512GB
Cooler Master V1200 Platinum / CM Storm Trooper
