New build won't post
Leatherneck
New build not getting any beeps at startup, Q_Code is 00, CPU and GPU fans come on but none of the case fans do, MB lighting does come on and nothing shows on the monitor.
I've gone through checking all power and other cables. Did a BIOS flashback with latest via usb. Cleared CMOS and removed battery for 5 minutes. Been searching for solutions but none found so far.
Any ideas?
The build has the following components:
ASUS Rampage V Edition 10
Intel i7-6850K
PNY Quadro M4000
G.SKILL TridentZ Series 128GB (8x16GB) DDR4 3200
Samsung 850 500GB SSD
Corsair RM1000X PSU
Thanks in advance!
18 REPLIES 18
sergio77
Any ideas?
Intel i7-6850K
PNY Quadro M4000
Corsair RM1000X PSU
Thanks in advance!
You could try:
- Reseat CPU;
- Check CPU socket for bent pins;
- Temporary replace PSU with another one, just to check it;
- Check the user manual for correct RAM sticks placement;
- Use only one RAM stick at once;
- Switch to BIOS #2
Intel Core i7-5930K @ 4.5GHz / Cooler Master Nepton 280L / Noctua NF-A14
Asus RAMPAGE V Extreme / Kingston HyperX 32GB DDR4 3000MHz
Asus Strix GeForce GTX 980 / Asus VX279Q
Samsung 950 Pro NVMe 512GB / Samsung 850 Pro RAID 0 512GB
Cooler Master V1200 Platinum / CM Storm Trooper
sergio77 wrote:
You could try:
- Reseat CPU;
- Switch to BIOS #2
Re-seated the CPU, same result
Hard to see but they look ok, will get a magnifying glass to look more closely -- was a small piece of plastic near side wasn't interferring with pins but cleared it and re-installed chip. But no change
Don't have another PSU on hand to try
RAM is correct
Tried the one stick of RAM, still same result
How do you switch to Bios #2?
jrmcdou
Have you double checked your power cables are all firmly connected? The cpu 4 pin and 8 pin, 24 pin and gpu power cables? Also do you have a self test button on your psu?
Rampage VI Extreme bios 1503
Core i9 7980XE @ 4.4ghz all cores
64 gb Corsair Vengeance RGB Pro 3600
2x RTX 2080 Ti FE NvLink/SLI
2x Samsung 970 Pro 1tb NVME
Corsair AX1600i
Corsair 1000D case
1x Dell U3818DW 38" Curved Ultrawide and 2x Dell S2716DG 27" 1ms GSYNC 2560x1440 144 hz
Win 10 Pro x64
Yep, all PSU connections have been double/triple checked, plugged and replugged
Don't have a test button on PSU
Thanks
Legolas
What LED do you have on the motherboard when you get qcode 00? CPU LED?
Sincerely,
Legolas
None of the LEDs light up
59022
red454
Level 11
Bios switch is at the very bottom right of the board (red button). Push it and watch the yellow LED switch from one chip to the other. The bios chips are also at the bottom of the board in the middle - next to the red USB 3.0 header.
ASUS Rampage V Extreme BIOS 4101 | i7-6950X | Thermaltake Core X9 | G.Skill F4-2800C16Q-32GRK | Cooler Master Nepton 280L | Dual Samsung 850EVO 500GB SSD | PSU: DARK POWER PRO 11 1000W | 3TB & 4TB HDD | NVIDIA GTX Titan X | ASUS 24x DVD±RW Drive | Win10 Pro
Found it, changed between the two but still same result
Chino
Level 15
