Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Guru: White Belt Array From0toHero PC Specs
    Laptop (Model)Asus G551JK Microsoft Surface Pro 3 i7 512gigs SSD
    MotherboardAsus Rampage V Extreme
    ProcessorIntel 5930k
    Memory (part number)Kingston Predator DDR4 32gigs (@2144mhz)
    Graphics Card #1MSI 980 GTX Ti 6G
    Graphics Card #2Asus 980 GTX Poseidon
    MonitorAsus PG279 ROG / Dell Ultra Sharp
    Storage #12 Samsung 850Pro 500gigs
    Storage #2Samsung 850Pro 1Terra/ Western Digital Red 3 Terra
    CPU CoolerCoolermaster Nepton 240m
    CaseCoolermaster Cosmos II
    Power SupplyBe-Quiet Dark Pro 11 1000Watt
    Keyboard Razer Chroma RGB
    Mouse Razer Ouroboros/ Logitech G602
    Headset Logitech G230
    Mouse Pad Razer Goliathus
    Headset/Speakers Harman Kardon Sabre SB35
    OS Windows 10 Pro
    Network RouterNetgear Nighthawk R7000
    From0toHero's Avatar
    Jun 2015
    82
    Rampage V Extreme vs Rampage Extreme 10 diffrences
    What are the main diffrences between this two Mainboards? Is it worth to change a very very stable system and update to the new version of the rampage?
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,670
    "Worth it" is very difficult to quantify unless you're Loreal and then we all are...
    I made the move and have to say I like the new board better. It is simply a bit more refined for the most part and I like the looks.
    The only real performance gain for me seems to be the new Ttopology... meant I have tightened some timings on my RAM for lower voltage...a work in progress...holidays interrupted...but nice progress already
    If cost is not an issue then I'd say go for it...
    OS Windows 10 Pro
    Jun 2015
    82
    Well its less a cost question than the work, benefit, and in general any diffrences. I dont overclock so i guess it would be a rather cosmetic change than a necasscery one
    Oct 2012
    339
    15,254
    If you want the new features, then yes, it's definately worth it. I made the change just like Arne did and I have no regrets.
    ROG Enthusiast Array sergio77 PC Specs
    sergio77 PC Specs
    ProcessorIntel Core i7-5930K
    Memory (part number)Kingston HyperX DDR4 3000MHz 32GB
    Graphics Card #1Asus Strix GeForce GTX 980
    MonitorAsus VX279Q
    Storage #1Samsung 950 Pro 512GB
    Storage #2Samsung 850 Pro RAID 0 512GB
    CPU CoolerCooler Master Nepton 280L with Noctua NF-A14
    CaseCM Storm Trooper
    Power SupplyCooler Master V1200 Platinum
    Keyboard CM Storm Trigger-Z
    Mouse CM Storm Sentinel Advance II
    OS Windows 10
    Nov 2012
    47
    Quote Originally Posted by From0toHero View Post
    New to specs for Edition 10
    - Memory: 8 x DIMM, Max. 128GB of DDR4;
    - Strorage: 1 x U.2 port, 10 x SATA 6Gb/s connector(s);
    - LAN: Dual Gigabit LAN controllers (plus one Intel® I211-AT Gigabit LAN Controller);
    - 2 x USB 3.1 integrated ports (Type-C and Type-A) ASMedia® USB 3.1 controller,;
    - AURA RGB: Aura Lighting Control, Aura RGB Strip Headers, Aura Lighting Effects Synchronization;
    - ASUS EZ Flash 3;
    - Pre-mounted I/O shield;
    - SafeSlot, the slot with the fortifying metal for an inherently stronger slot.
    Intel Core i7-5930K @ 4.5GHz / Cooler Master Nepton 280L / Noctua NF-A14
    Asus RAMPAGE V Extreme / Kingston HyperX 32GB DDR4 3000MHz
    Asus Strix GeForce GTX 980 / Asus VX279Q
    Samsung 950 Pro NVMe 512GB / Samsung 850 Pro RAID 0 512GB
    Cooler Master V1200 Platinum / CM Storm Trooper
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    If you don't have problems maybe you should stay and on old version.
    First board is very nice as well, I liked RVE from first day.
    but if money is not problem Black version is much better board with more features and better if you want to keep X99 longer,
    even owners are more satisfied with Black and report less problems.
    That's always hard decision, if your board make you problem I would say Yes immediately, but you say Stable than I don't know...
    If you want Skylake-EX maybe is better to wait next Rampage.
    Anyway you will be more happy if you buy Black version, I know that.
  7. #7
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,336
    There was a few things for me when I changed:
    - New water pump fan header and HW fan header
    - Fan extension board (nice to have with 13 fans)
    - Fan xpert 4 which is much nicer than 3
    - Lighting and Aura makes it look very puuuuurdy
    - The overclock and overall board seems a lot more stable than the R5E - I had corrupt BIOS and my system would hang in BIOS needing to be reset and overclocked about every 20 reboots. No problems with Edition 10
    - The DAC if you want that
    - More features like Ram Cache which never worked well with my older R5E
    - As stated before, tighter memory timings. I was able to get my Corsair Platinum 3200 RAM down to 14-15-15-36 T1 with .01 voltage increase. Old board never got better than 16-18-18-39
    For me it is worth it.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  8. #8
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    Brightfall are you satisfied with Rampy Black now, I knew you had some special moments...
    Now before 10 minutes I installed USB driver and suddenly I see from other room stay picture of BIOS on monitor.
    What is now restart, again BIOS, I checked in boot section NO my OS driver... WTF...
    And I remove SSD in P3 and now I see him. I can't check is it Port 1 OK. haaa haaa I afraid to check.
    And My god ASUS...people, engineers, designers... How you recommend to someone remove GPU from first slot?
    Because My recommendation is to use peace of cardbox and roll and push plastic lock between GPU and ROG LED Logo...
    BECAUSE I CAN'T TOUCH LOCK WITH FINGERS and I never pull GPU before I move locker. I mean it's not some big problem at all, only little tricks need.
    I don't know what to think, my minds are confused,
    I'm happy because I don't need to destroy documents on HDD before I order 1TB SSD and I afraid little because I don't know what is with my Port 1.
    We will see when SSD and M.2 arrive.
  9. #9
    Brighttail PC Specs
    Mouse Asus SPATHA
    Sep 2014
    33
    1,336
    Yeah I'm happy with it. I think the first board I got was simply a dead board.
    The second one it looked like it was a BIOS chip and when I switched to the backup BIOS everything worked great. I have gotten a new BIOS chip for the first one and all is good there.
  10. #10
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    Quote Originally Posted by Brighttail View Post
    That's excellent news. When board work OK everything else is much easier.
    Now you will love your board every day more and more. It's obvious that new version is better and worth higher price.
    Yes it's expensive, but customers usually use one platform for 2-3 graphic cards.
