Results 1 to 8 of 8
    ROG Member Array
    Jan 2013
    18
    Thumbs up Does Asus even quality control bro? (PG279Q)
    PG279Q
    First one had insane back light bleed.
    And this one.. Well.. I don't even
    Asus Maximus VIII Ranger
    i7 - 6700K
    Corsair Vengance LPX 16GB DDR5
    EVGA Titan x2
    Samsung 840 250gb, Intel 330 120gb
    Corsair HX1000i
    Ex-employee Array
    Jun 2020
    108
    2,154
    Did you receive the replacement from retailer or from ASUS service? If it's from the retailer then it's very likely a case where a user damaged the monitor and returned to the retailer for refund and claimed it was never opened and the retailer didn't bother to check and you were replaced with a damaged monitor. I personally have had this happen to me before and the retailer found out and explained to me that it was believed to be BNIB but after checking history that the same unit was sold to another customer and returned previously.
    ROG Member Array Hertz PC Specs
    Hertz PC Specs
    Laptop (Model)MacBook Pro 15" Early 2013
    MotherboardRampage IV Black Edition
    Processori7-4280k
    Memory (part number)2x F3-2400C10Q-16GZH G.SKILL Ripjaws Z Series 16GB (4 x 4GB)
    Graphics Card #1ASUS GTX980 Strix
    Graphics Card #2ASUS GTX980 Strix
    Sound CardCreative Sound Blaster Z
    MonitorASUS PG279Q
    Storage #1Samsung 950 Pro 1TB
    Storage #2Seagate Constellation ES ST32000644NS 2TB 7200
    CPU CoolerNoctua NH-D14
    CaseCoolerMaster HAF-932
    Power SupplyEVGA SuperNova 1000W P2
    Keyboard Razer Tron
    Mouse Razer Tron
    Headset SteelSeries Siberia v2
    Mouse Pad Razer Tron
    OS Windows 10
    Network RouterLinksys EA6400
    Oct 2013
    11
    I've opened 10 (!!!) displays from September/October batches and they all had foam sticking in the bottom right corner just as the topic starter shows, so no, it's not a retailer issue.
    ROG Guru: Orange Belt Array
    Jun 2015
    21
    432
    Quote Originally Posted by Hertz View Post
    Probably a great idea to take picture of all 10 and show it here to show some credibility.. 10 that has the same problem sounds like a bit over exaggerated since I opened 3 boxes with my buddy who just bought 3 of these like recently and none of them had this problem.
    ROG Member Array IntrudaH PC Specs
    IntrudaH PC Specs
    MotherboardMaximus VIII GENE
    Processori5-6600K
    Memory (part number)Corsair CMK16GX4M4A2800C16B
    Graphics Card #1EVGA GTX970 SSC ACX2.0
    Sound CardODAC
    Power SupplyCorsair RM650x
    OS Windows 10 Pro
    Network RouterMikrotik RB2011UiAS-2HnD-IN
    Jan 2016
    5
    I must be terribly lucky with lotteries (time to buy an Euro jackpot ticket) because mine has a very minimal BLB, and I got it with a discount of -25% as a shop demo. There is no foam coming out anywhere either, maybe I don't know where to look. February 2016 build.
    To be fair, I use it with brightness of 0, it's plenty for my lighting conditions. Sometimes I up it a bit to 12, if it's sunny outside. When I crank the brightness up to default 80 or more, there is definitely some mild yellowish BLB noticable on lower and upper right corners on a black test screen but it looks nothing close to the exaggerated pictures you can find on your internets.
    One thing I must say - the IPS glow is the strongest I've seen of any of IPS monitors I had, and most pronounced in both right corners. I'm sure at least part of those problem reports come from previous TN panel users who take IPS glow for a BLB.
    Overall, I'm pretty happy with the picture and monitor in general. One thing that annoys me though is the lack of shortcut button for input switching, even more that the vertical line/Gsync issue which I had a couple of times.
    Moderator Array
    Jul 2016
    12
    205
    Whoa, was this monitor brand new, or refurbished? That's amazing if it's brand new and came like that. Did you get it replaced?
  7. #7
    ROG Member Array
    Jan 2013
    19
    Wow... and I was complaining about small micro scratches in the panel from the bubble wrap. I don't even know what to say to that...
  8. #8
    Hertz PC Specs
    Processori7-4280k
    MonitorASUS PG279Q
    Keyboard Razer Tron
    Mouse Razer Tron
    OS Windows 10
    Oct 2013
    11
    Quote Originally Posted by InfernoStorm View Post
    Yes but of course, I'll return to the store just for you and ask the retailer to give me the exact same displays after 7 months to take a photo.
