Results 1 to 6 of 6
Thread: Triple monitor
    ROG Member Array
    Oct 2015
    8
    Triple monitor
    I want to know if with the new asus strix (GTX 1070/RX 480) can run a triple monitor set up, (gsync / freesync). I know those monitors needs DP conector, but the new strix just come with 2 Dp and 2 HDMI 2.0, just that, thx for the help
    ROG Guru: Orange Belt Array
    Dec 2011
    24
    293
    Do a Google search - I've run across companies that have HDMI to DP adapters.
    Lian-Li PC-A77F Full Tower case
    PC Power & Cooling Turbo-Cool 1200 ATX12V & EPS12V PSU
    ASUS Rampage IV Extreme LGA 2011 X79
    Intel Core i7-3960X 3.31 LGA 2011 CPU
    Intel RTS2011LC Liquid Cooling Solution
    Kingston KHX24C11T3K4/32X (quad 32Gb memory kit) 2 each
    ASUS Radeon HD7970 DirectCUII 3Gb GDDR5 PCIe 3.0 x16 Video Card (two in CrossfireX Mode)
    Western Digital Cavier Black 2Tb SATA III 6.0GB/S
    OCZ Technologies Vertex 4 SATAIII 6Gb/s 512Gb SSD
    ROG Enthusiast Array
    Apr 2016
    31
    Quote Originally Posted by Runaway_11 View Post
    Just got two Asus ROG Strix GTX-1080-A8G-GAMING cards, and to do Triple Monitors w/o turning SLI, (aka Activate All Monitors) they all need to be hooked up to the first card only. Otherwise you'd need to enable NVidia Surround, and probably a HB bridge (I have two ribbon SLI Cables, and running anything in 3D on Nvidia surround with monitors attached to different cards caused corruption...not so if only one card had all the monitors)
    This is relevant I guess to just the Pascal card. I would assume AMD's Eyefinity isn't as broken as NVidia's Surround after all these years.
    ROG Member Array
    Oct 2015
    8
    1910
    Thx for your answer, i got the same info from another way, you are right, 3 monitors must be conected to same card.
    Btw, i just want fresync / gsync, not 3D, and in this web: http://wccftech.com/amd-talks-freesy...1-3-hdmi-2-0a/
    says freesync will be cappable over HDMI, and not just DP. The truth its there is not any monitors yet.
    So i dont know what to do, if get a card with 3 DP or just the asus.
    ROG Member Array
    Oct 2015
    8
    ROG Guru: Blue Belt Array sectionate PC Specs
    sectionate PC Specs
    MotherboardAsus Crosshair V Formula
    Processor8350 - 1090T
    Memory (part number)G Skill Sniper F3-14900CL9-4GBSR
    Graphics Card #1Asus GTX660-DC2O-2GD5
    MonitorAcer GD235HZ - ViewSonic VX2439wm - SyncMaster P2350
    CPU CoolerCorsair H100i
    CaseHAF 932
    Power SupplyCorsair Professional HX850
    Mouse Zowie EC1 eVo
    OS Microsoft Windows 7 Enterprise 64bit
    sectionate's Avatar
    Feb 2012
    57
    878
    wide·screen gam·ing fo·rum (wsgf):
    [-noun] Web community dedicated to ensuring PC games run properly on your tablet, netbook, personal computer, HDTV and multi-monitor gaming rig.
    http://www.wsgf.org
    Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
