Results 1 to 7 of 7
    ROG Member Array
    Aug 2016
    21
    Stuttering? Low FPS? GTX 1070/1080
    Say you watch some show you downloaded or maybe a youtube clip, anyone here experiencing stutters at the beginning? Apparently this is mitigated by changing the power management under NCP from optimal to max performance. At least for me it did.
    Also, anyone get low fps sometimes? I hear changing vsynch under NCP again from 3d setting to off helps rid it.
    Maybe this doesn't happen to newer systems as mine is 8 years old (planning upgrade next year) or maybe my i7 920 or ram is bottlenecking the system as a whole to cause such stutters at the beginning. Safe to say I never had stutters on the AMD 5870 Matrix before I upgraded to a Strix.
    ROG Enthusiast Array
    Jul 2016
    40
    Quote Originally Posted by Morisato View Post
    no stuttering here. But the temps of the gpu seems to be a bit hotter. I use optimal, i like my system to be runnin cool.
    ROG Member Array
    Aug 2016
    21
    Quote Originally Posted by protos View Post
    You and me both. Hopefully this is just a case of the system being old and the rest needs to be upgraded. Newer cards handle temps way better from what I can see as my old 5870 was running at 70c+ but the new Strix never really goes above 54c with max performance enabled. I'll try optimal again once I upgrade.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Did you uninstall the AMD drivers thoroughly? If not, try running Display Driver Uninstaller.
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,467
    On your place I would clean everything and NVIDIA and ex AMD driver with DDU or Driver Cleaner Pro, off course in safe mode.
    First uninstall driver and than boot in safe mode and clean.
    Than choose Custom install and check Clean Install, only Display Driver and PhysX if you not use 3D, you don't need NVIDIA Experience.
    I think with last driver and physx only situation should be better. You could overclock your CPU little because X58 is little old.
    Still is good but you need all power from him.
    ROG Member Array
    Aug 2016
    21
    Guess I will give that a try then. Yes, I always use DDU before upgrading to a new driver. Usually I just uninstall driver, reboot, DDU, reboot, install new drivers, reboot. Never really needed safe mode but I guess it doesn't hurt. Right now I am contemplating if 372.70 is better fps wise than 372.54 or not besides the minor issues it's fixed in the release notes.
    Also, does it take about 4-5 minutes to DDU NVidia drivers for you? For some reason it takes about that long for me while it takes about 15-30 seconds for AMD. Not sure why that is the case. It stops at uninstalling drivers then stays there for some time before finishing up.
  7. #7
    Jul 2016
    40
    oops wrong thread
