Results 11 to 20 of 50
10-16-2016 06:00 AM #11
- Join Date
- Jun 2020
- Reputation
- 108
- Posts
- 2,154
Hi Dark,
This lag issue is only occurring for those with newer AMD cards, this is the first time I've heard of this issue with Nvidia card. The issue with the AMD cards have been fixed with latest AMD drivers.
Please confirm which version of GPU Tweak II you're using and also your graphics driver.
In additional if you can also share you full system specifications including your system OS (build and language), and also list of all other applications installed.
Thanks,
Bahz
10-16-2016 07:27 AM #12
DeathtoGnomes PC Specs Motherboard Sabertooth 990FX Rev2.0 Processor AMD-9370 @4.4 not OC'd Memory (part number) 2x8g G.skill Graphics Card #1 R9280X-DC2T-3GD5 Sound Card on-board Monitor 2x Dell 2440L Storage #1 60SP 240G SSD Storage #2 2TB + 1TB + 1TB platter drives CPU Cooler CM Nepton 280L Case Phanteks Enthoo Primo w/10 fans Power Supply Corsair HX1000i Keyboard Logitech Orion Spark Mouse Logitech G700s Headset Cool something.... Mouse Pad Vanguard:SOH image one Headset/Speakers Spks: AC43 OS win10
- Join Date
- Aug 2014
- Reputation
- 13
- Posts
- 84
@Bahz ya know, that makes sense why GPUTweak has so many different issues, its reading and depending on drivers from AMD and Nvidia. I think if that can be changed so that it can be run from a stand-alone zip file [folder], GpuTweak (atleast) would have greatly improved performance and less issues. Smaller is better.
OH and stop saving settings in the REGISTRY, it unnecessarily adds clutter to the REGISTRY is really slowing that down (can be proven) which in turn slows windows performance. Use .ini, .cfg, or whatever else works.
EDIT:meant Registry not BIOSLast edited by DeathtoGnomes; 10-17-2016 at 11:33 PM.
SpeedFan controls fans and temps, once you learn how to configure it properly.
10-16-2016 08:00 AM #13
- Join Date
- Jun 2020
- Reputation
- 108
- Posts
- 2,154
Thanks for the feedback, I'll be sure to pass it on
10-16-2016 08:56 AM #14
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 4
Some sort of update to this post or news of some kind would of been appreciated as soon as it was known that updating to newest AMD drivers fixes this issue.
Here I am waiting for a new version of GPU Tweek to come out, had no idea that new AMD driver fixed the issue when using 1.3.6.0
Can confirm that with the latest driver (I'm using AMD's beta 16.10.1) with GPUTweek II 1.3.6.0 that the issue is gone and is fully working.
10-17-2016 11:33 PM #15
- Join Date
- Aug 2014
- Reputation
- 13
- Posts
- 84
10-18-2016 01:12 AM #16
- Join Date
- Jun 2020
- Reputation
- 108
- Posts
- 2,154
I was thinking as well how you save to vBIOS, I updated your feedback as I didn't hear back from our engineer yet.
10-18-2016 05:17 AM #17
- Join Date
- Oct 2015
- Reputation
- 10
- Posts
- 9
Hi Bahz,
I'm currently running Win10 Enterprise x64 (screenshot attached)
GPU: Asus GTX 1070 OC Strix. Driver Version: 373.06
The version of GPUTweak II i used was the latest one, GPUTweak2_Ver1360_20160817. I also tired installing the the Aura app (without GPUTweak) and experienced the same issue. I used version VGA_AURA_InstallationV0.0.4.1. I have all the standard apps installed on my PC, nothing special. The only tuning apps I have installed are FRAPS and RivaTuner
Troubleshooting includes
GPUTweak II was working fine with my previous Nvidia card (Asus 970 Strix)
Reinstall the GPUTweak app using Programs and Features and via running ASUS GPUTweakII RemoveTool V1009_20160824
Removed RivaTuner
Installed MSI Afterburner to test - works perfectly fine without any issues.
Looking forward to your reply soon!
10-21-2016 09:23 AM #18
F3niX PC Specs Motherboard Gigabyte Z77X-D3H Processor Intel Core i7-3770k @ 4,2Ghz Memory (part number) Kingston HyperX Fury 2x8GB 1866Mhz Graphics Card #1 Asus ROG Strix GTX 1070 OC Monitor Dell U2515H Storage #1 Samsung SSD 840 Evo 250GB Storage #2 WD Black 1TB CPU Cooler CoolerMaster Hyper 212 Evo Case BitFenix Shinobi Window Power Supply EVGA SuperNOVA G2 750W Keyboard Razer Lycosa Mouse Razer DeathAdder 3.5G Headset Razer Kraken 7.1 Chroma Mouse Pad Corsair MM300 OS Windows 10 Pro x64
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 41
Windows 10 lagging still there in GPUTweak2 Ver1.3.9.7. My card is 1070 strix oc
All i did was install the new version, go straight to settings and enable overclocking range enhancements. after that i right clicked on the desktop and it was laggy.
Disabling the option didn't undo the problem
10-28-2016 08:25 AM #19
- Join Date
- Oct 2015
- Reputation
- 10
- Posts
- 9
Joyce comunale
Dear Bhaz,
Any update on this?
Thanks.
10-29-2016 01:27 PM #20
- Join Date
- Apr 2016
- Reputation
- 10
- Posts
- 12
Updated to the newest GPUTweak II and I'm still having the weird graphical glitches and lagginess. Ending the Desktop Window Manager process so it can restart resolves the issue again.
All I did was turn off monitoring, unlinked the monitor, then closed the window, set to OC mode, went into options to turn off monitoring starting up and hit apply. Didn't even touch Info or Tools.
STRIX 1070 OC
Windows 10 - 1607 Build 14393.351
375.70 driver
