Results 1 to 4 of 4
    ROG Member Array
    Jul 2015
    21
    ROG G751JY Monitor driver and 100hz if possible
    Hi guys,
    I reinstalled W10 in my G751JY and I noticed that the integrated monitor is recignized as Generic PnP monitor so I was wondering if there is a driver for it somewhere (couldn't find it in the ASUS driver page) and if there is a way to go at 100hz.
    My laptop is the one already GSync enabled (didn't need modded driver or so).
    Any tips?
    Thanks,
    Max
    ROG Member Array
    Jul 2015
    21
    anyone?
    ROG Guru: Yellow Belt Array
    Mar 2015
    176
    u can manuelly set in Nvidia Panel ure Refresh Rate from Monitor to 100hz, without problem
    http://www.directupload.net/file/d/4476/lfg6nurm_png.htm
    i play with this settig most of the new games without problems and idk but no tearing or some.like that..
    ROG Member Array anasmy PC Specs
    anasmy PC Specs
    Laptop (Model)Asus ROG G751JT
    MotherboardAsus Maximus VIII Hero
    ProcessorIntel Core i7 6700K
    Memory (part number)2x Corsair Vengeance LPX 8GB 3200MHz DDR4
    Graphics Card #1Asus Radeon RX480 Strix
    MonitorPhilips 223V (Temporary)
    Storage #1256GB Samsung 850 EVO
    Storage #2480GB Kingston HyperX Savage
    CPU CoolerBykski Custom Loop Watercooling
    CaseCorsair SPEC-ALPHA
    Power SupplyCorsair AX860
    Keyboard Logitech G910 Orion Spark
    Mouse Corsair Scimitar RGB
    Headset Corsair Void USB 7.1 Yellowjacket Edition
    Mouse Pad Razer Goliathus Extended
    Headset/Speakers Audio-Technica ATH-M30x
    OS Windows 10 Pro x64 + OS X El Capitan + Ubuntu 16.04
    Aug 2016
    11
    All G751JT/G751JY are capable of 100Hz if I'm not mistaken. Just set a custom 1920x1080 resolution with a refresh rate of 100Hz on nVidia Control Panel
