Results 1 to 5 of 5
    ROG Member Array
    Feb 2013
    5
    Fan control questions on Extreme VIII
    Hi Folks
    A couple of questions about fan control on the Maximus Extreme VIII
    - Which temperature sensor is used to determine the temperature on the Q-fan control profiles?
    - Is it possible to specify which temperature sensor is used to control fan duty cycle?
    - Is there Windows software to configure more advanced Q-fan control settings?
    Thanks very much
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    The answer for question 2 and 3 is probably the Fan Xpert utility that's included in the AI Suite.
    ROG Member Array
    Feb 2013
    5
    I have downloaded AI Suite however I can't find Fan Xpert
    ROG Member Array ricemanhk PC Specs
    ricemanhk PC Specs
    MotherboardAsus ROG Maximus VIII Hero Alpha
    ProcessorIntel i7-6700k @ 4.6GHz
    Memory (part number)Corsair LPX 16GB 2400MHz
    Graphics Card #1MSI GTX 1070 Gaming X 8G
    Storage #1Samsung 950 Pro 256GB M.2 PCIe x4
    Storage #2WD Blue 3TB
    CPU CoolerCorsair H100i v2
    CaseCorsair Carbide 400C
    Power SupplyEVGA Supernova 850W B2
    OS Windows 10
    Sep 2016
    21
    You can set this in the BIOS or in the Fan Xpert in AI Suite (it's a module within AI suite, 2nd box on the left on the main page). Default is all linked to the CPU temp
    Yes, you have a choice of the CPU, VRM, PCH, or motherboard temp sensor. You can also add external temp sensor probe on the 2pin header on the mobo, and you get yet additional ones if you add the optional fan header module.
    Fan Xpert in AI Suite. Does the same thing with the q-fan settings in BIOS, and I find setting it in the BIOS means the fans already follow my profile during POST/boot up, instead of only after windows loads. Small difference, but the default profile esp for PWM fans have them spin at like 60% for idle.
