Results 1 to 7 of 7
    ROG Enthusiast Array
    Aug 2016
    37
    For those with Bluetooth problems!
    Today's Windows 10 update includes "Bluetooth compatibility" fixes. Let me know if they help you. I have occasional USB and Bluetooth random drop outs, so I'm hoping it will become more stable. USB fixes were also included.
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,321
    Nope.. Nothing.
    I ended buying a bluetooth dongle and am very displeased with my need to do this.....
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator Platinum SE 4x8 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p in a bootable VROC RAID 0 / Samsung 960 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Spatha
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,456
    Anyway now I will transfer files more with iTunes not with Bluetooth.
    But on RVE and Windows 7 work.
    Problem is Windows 10 or RVE10
    Aug 2016
    37
    Since I asked that question, my Bluetooth has vanished completely. Sigh. Given the other issues I've had with this board, I might send it in for RMA and then sell.
    Sound and Bluetooth are definitely ongoing problems, especially in Windows 10. Might as well rebuild with something new.
    Mar 2016
    12
    65
    Quote Originally Posted by bowman9991 View Post
    I can remember a bunch of previous Windows 10 hotfixes promising to fix USB & Bluetooth. They never did anything good for my rig. As far as I'm concerned, I consider the USB implementation broken on RVE due to the ASMedia chips they jammed on the board some working as hubs.
    Aug 2016
    37
    Quote Originally Posted by linxeye View Post
    You could be right. Lots of USB problems here too. Connecting/disconnecting sounds. Intel Real 3D camera not working. Then does work.
    USB device not recognised (could be Bluetooth but who knows). Bit of a mess really.
  7. #7
    Mar 2016
    12
    65
    Never managed to get the Intel camera working on this mobo (RVe) or the X99 Deluxe phase 1. Best solution : grab yourself and addin USB 3.xx controller card and route most of yoru critical USB devices there.
